HX Stomp Series Parallel Violume drop
petermengede
I'm running my HS Xstomp in the loop of my quickrod using effects only.
When I route my preset effects along path B ( parallel) I get full volume but not an optimal effect integration.
When I route my effects along path A (series) I get a serious volume drop in the order of 5 to 6 db, even with all effects bypassed.
Is this normal and if so how is this dealt with?
Thank you
Thank you
Someone asked a very similar question earlier today.
Simple answer - yes, it is normal and it involves a little bit of the science of physics named "Pan Law".
Strap in - Here is the explanation for the difference in level when a path is split.
Hope this helps/makes sense.
