LoudenDeri Posted November 4, 2023 Share Posted November 4, 2023 Does anyone know what can cause this? I never had this problem until I updated recently. I also get random volume swells every once in a while. In a four hour gig, it might happen 3 times, but not always. Not 100% sure this is the HX Stomp, but since I am having the issue with the pop sound going into tuner mode, I think it MIGHT be. Thanks for any help on this! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 4, 2023 Share Posted November 4, 2023 No pop on mine. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 4, 2023 Share Posted November 4, 2023 On 11/4/2023 at 1:34 PM, LoudenDeri said: I never had this problem until I updated recently. Hi, I don’t have Stomp, mine is the Helix floor, but this is not something that I have experienced while switching to the tuner. I notice this is your first post to the forum, plus you mentioned a recent update . Therefore I will ask - after performing the firmware update, did you perform a factory reset and go through the preset update routine. Then did you re-install your back up bundle file that also contains the Global settings for your hardware? First rule of Helix club - if something starts to behave in a weird manner, perform a factory reset on the device. Hope this helps/makes sense. You can find the reset options here: https://helixhelp.com/tips-and-guides/universal/reset-options Quote Link to comment Share on other sites More sharing options...
LoudenDeri Posted November 5, 2023 Author Share Posted November 5, 2023 Ok, thanks I will try a factory reset. 1 Quote Link to comment Share on other sites More sharing options...
mightyhammerhead Posted April 2, 2024 Share Posted April 2, 2024 I have the pop problem also... If I discover any solutions I'll post it. Quote Link to comment Share on other sites More sharing options...
