JPaul2 Posted November 13, 2023 Share Posted November 13, 2023 I like my Catalyst (60) but would like it better if I could find a work around.... When you make a manual change to a channel and then go to the other channel, the change you made to the first channel is still retained (without saving). Am I the only one that is unhappy with this "feature"? Is there a way to disengage this "auto-save" type of response? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 13, 2023 Share Posted November 13, 2023 Catalyst models a real amp in this respect. On a real amp with two distinct channels with separate G/B/M/T/P/V controls, if you make a change to one channel and then switch to the other channel, will the physical knobs return to their original positions? Of course not. If you want a workaround it requires MIDI. EDIT: OR If you tap the Channel A or B button again for the modified channel, it will reload the saved preset throwing away the modification. Thanks to @txfloodfor this reminder If you use MIDI to switch channels, since each "channel" is actually a separate preset, the original saved preset will reload. Using the FS, however, will mimic the way a real amp works. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 13, 2023 Share Posted November 13, 2023 Anticipating your next post, you'll need a host box to do this with MIDI on your Cat60. This is one reason that whenever someone posts "Which one should I get?" I always say get the Cat100. The usual response is "I don't need MIDI.". Later on... Quote Link to comment Share on other sites More sharing options...
txflood Posted November 16, 2023 Share Posted November 16, 2023 If you tap the Channel A or B button again for the modified channel, it will reload the saved preset throwing away the modification. 1 Quote Link to comment Share on other sites More sharing options...
