Helix Floor/LT/Rack v3.7 (and3.8) Factory Setlists
silverhead
On 11/16/2023 at 3:26 PM, guitarman5560 said:
I'm getting set to pickup my new Helix floor tomorrow. Its brand new. Not sure what the firmware version will be but in case its a couple behind do I need to apply them one at a time or will updating with 3.70 give all updates even if its behind a couple?
The v3.70:firmware update (as all are with Helix) is comprehensive. No need to install any earlier updates first. Just download the HX Edit v3.70 package and install all components. Then run HX Edit with your Helix device connected via USB. Read the Release Notes for detailed installation instructions and follow them carefully.
From the Release Notes (linked in my earlier post above).
My Helix/HX is at version X.XX. Can I go straight to 3.70?
Yes, but note that if you're starting from 2.80 or lower, the update may appear to happen three times and will take notably longer than 30 minutes. This is normal.
Hope this helps/makes sense.
  • Thanks 1
  • 1 year later...
  • silverhead changed the title to Helix Floor/LT/Rack v3.7 (and3.8) Factory Setlists
