Need some suggestions, HD300 fizz tone
indyj_son
Hello!
Playing around with some old gear. I never tried the Line 6 link so I was messing with it with my DT25 head and HD300.
The tone I am looking for is hard to heavy but not super metal, something you can roll the volume back and get an OD clean-like tone.
I have settled on the JCM800 model. In general I like the sound but there is this annoying high "fizz or brittleness" I just can't get rid of. Rolling the Presence down helps a bit but it is still there. If I could just get rid of it my tone would be perfect. Any suggestions? The DT25 is like new with very low hours on the stock tubes. I am running it through my line 6 4x12 with Vintage 30's.
My HD300 settings are:
Live mode
Amp set to PreAmp mode
Setup output = Stack Amp
Line 6 link to amp.
No FX1
Any suggestions with some settings to play with greatly appreciated!
Try putting a MID FOCUS EQ after the pre-amp in your POD patch to use its included Low Pass Filter (sort of like a HIGH CUT).
By default, two MF EQ parameters that are not needed in this case are active and therefore must first be neutralized by setting them to zero: the GAIN and HP FREQ.
The parameter that serves as HIGH CUT is the LP FREQ, setting it to a value between 63 and 70 (depending on the amp model chosen) should solve the fizz problem.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Thanks for the suggestions but the HD300 does not have the Mid F EQ. It does have the 4 band and Parametric. I messed around with the 4 band a bit but still was not quite able to get what I am looking for.
You're right, I use a HD500X and I didn't remember that the HD300 didn't have the MF EQ.
But I think that the HD300 should be equipped at least with the Vintage Pre which also contains a Low Pass Filter which you could use for the same purpose.
In this case the values would be more conveniently expressed in kHz, and a setting more or less around 6 kHz could be what is needed..
