Drybonz Posted March 11 Share Posted March 11 My snapshots were fine at one point but I've noticed, now, that if I make changes to an effect in one snapshot it is changing it in all three. I thought this would be related to the recall/discard setting, but switching it doesn't seem to have changed anything. Is there something else I might need to change? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 11 Share Posted March 11 You need to FIRST assign the PARAMETER to SNAPSHOTS, then SAVE the preset (If EDITS is set to DISCARD) with the Parameter set as you want it in each SNAPSHOT. If EDITS is set to RECALL then you can set it in all SNAPSHOTS and SAVE once when done. If you think that you're doing that, attach a copy of the PRESET (NOT a screenshot) and I'll look at it. Quote Link to comment Share on other sites More sharing options...
Drybonz Posted March 11 Author Share Posted March 11 Just to be clear, if I make any changes on one snapshot, it is immediately changing all three. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 11 Share Posted March 11 On 3/11/2024 at 6:15 PM, Drybonz said: Just to be clear, if I make any changes on one snapshot, it is immediately changing all three. That suggests that you have not assigned the parameters to the Snapshot controller. A parameter that is properly assigned to the Snapshot controller will appear with white brackets around it. 1 Quote Link to comment Share on other sites More sharing options...
Drybonz Posted March 11 Author Share Posted March 11 Ok... that would probably be it since I don't know how to do that. Oddly, they were changing individually for me in the past, so I must have done something right without knowing it. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 11 Share Posted March 11 On 3/11/2024 at 4:22 PM, Drybonz said: Ok... that would probably be it since I don't know how to do that. Oddly, they were changing individually for me in the past, so I must have done something right without knowing it. In HX Edit, right-click on the parameter and choose SNAPSHOTS. A little camera icon will appear on the left of the parameter and the VALUE field will be in parenthesis. 1 Quote Link to comment Share on other sites More sharing options...
Drybonz Posted March 12 Author Share Posted March 12 Ok... thanks guys. I'm going to try this tomorrow and see if I can get everything working properly. Quote Link to comment Share on other sites More sharing options...
GlennDeLaune Posted July 3 Share Posted July 3 To fix this issue, set the "Stomp Select" setting in the Global Footswitches to "Touch". Then touch the snapshot button that is taking two clicks, make sure the "Type" setting is set to "Momentary". If it's set to "Latching" it will cause that snapshot to take 2 clicks to engage. Hope that clears it up for you. Glenn DeLaune Official Website | Official Youtube Channel | Official Facebook Quote Link to comment Share on other sites More sharing options...
