Mission Engineering SP1-L6H Expression Pedal on HX Stomp XL - Global Volume?
DdC441
I have a Stomp XL and the Mission Engineering SP1-L6H expression pedal (the one with the toe switch). I currently can assign two blocks to be controlled separately by the pedal, switching between them with the toe switch (Volume or Gain for example). I would like the Volume control to be Global and use the toe switch to switch the pedal to control a block in the preset (Gain for example).
Currently I must add and assign one of the 8 blocks in each preset to Volume and then add and assign the second block. I want that block back! Is there a way to assign Volume globally, so it works on every preset without using a block? I would then use the toe switch to select the second block in the current preset to control with the pedal.
I hope that makes sense. Does anyone know if this is possible? Thanks!
