jtfreed Posted March 29, 2024 Share Posted March 29, 2024 If I have a mono signal going into the 1/4" L/Mono input of the HX Stomp, and then I have stereo coming out (L and R 1/4" each going to a separate amp), what happens if I bypass all with the true analog bypass? Does the bypass relay basically work as a splitter, i.e., does the analog signal get passed through to both the L and the R outputs? Or do I only get a signal at the L/Mono output? Thanks for any insight here! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 29, 2024 Share Posted March 29, 2024 Signal to both L and R, unless only L is connected. 1 Quote Link to comment Share on other sites More sharing options...
jtfreed Posted March 30, 2024 Author Share Posted March 30, 2024 Ah, I see. Thanks for the info. So if I want a stereo signal coming out during bypass, I have to split it before the pedal, and go into both inputs. Makes sense. Thanks! Quote Link to comment Share on other sites More sharing options...
brue58ski Posted April 1, 2024 Share Posted April 1, 2024 I don't think that's what he was saying. I think he was saying that if you have a mono source and both the left and right outputs are plugged into something from the Helix, you will get a stereo signal provided your patch is stereo as well.. If you only have the left output going to something and nothing plugged into the right ouput, it will be mono. It's supposed to be summed but I think there may be issues. There was a thread about something like this somewhere. Try this thread. I think it may answer your questions and describe the issues with L/MONO - R ouputs. Like it doesn't sum left and right when only one thing is connected to the left ouput. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 1, 2024 Share Posted April 1, 2024 On 3/29/2024 at 1:50 PM, jtfreed said: If I have a mono signal going into the 1/4" L/Mono input of the HX Stomp, and then I have stereo coming out (L and R 1/4" each going to a separate amp), what happens if I bypass all with the true analog bypass? Does the bypass relay basically work as a splitter, i.e., does the analog signal get passed through to both the L and the R outputs? Or do I only get a signal at the L/Mono output? Thanks for any insight here! Seems pretty straight-forward, and that's how I tested it. In analog bypass mode, both outputs functioned as expected - LEFT went LEFT and RIGHT went RIGHT. How in the world do you get two signals from each Output in analog bypass mode??? IIRC, that whole linked discussion was very confused, and I was never able to duplicate the problem that the person who was pushing that theory was describing. Quote Link to comment Share on other sites More sharing options...
