bhouse1 Posted April 17 Share Posted April 17 Hi, I'm just about getting to grips with this pedal and it's enormous creative potential but in order for this to become my 'go-to' Delay I require the pitch glide is turned off! skipping from one tempo to another on each respective delay, creates all these pitchy artefacts that make using it as an 'all purpose' delay useless. I can't see anything in the global settings to address this issue at all? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 17 Share Posted April 17 Are you talking about an actual pitch glide, or are you just referring to artifacts that are introduced with a tempo change? If the latter, that’s a natural effect that occurs in the analog world as well when you instantaneously change the delay tempo. I’m not sure how to counter that, but I don’t have any experience with the DL4 MKII. There is a Global Setting that specifies whether tempo is associated with presets or is handled globally. Try setting this to Global and see if the artifacts disappear. Not ideal because then you would need to change tempo manually every time you want a change. Quote Link to comment Share on other sites More sharing options...
