HX Stomp - Cab Emulation on USB only
benjtosh
Hello,
I couldn't find an answer for this anywhere online - nor workout if its possible myself.
I have my Stomp set up via 4CM but wouldn't mind being able to record via USB simultaneously  - is it possible to have a cab sim set up that'll go to the daw via USB but not on the main out to a physical cab?
KR
There are likely several ways. My first thought is to use a split path preset with the cab sim alone on Path B. Split your paths just before the Output blocks. Path A output will use USB 1/2 and the Main outputs as usual for routing to your amp. Path B Output will use USB 3/4 so set the Record Input in your DAW to receive the incoming signal on USB 3/4.
If you need details on how to set up a split path with a Path B output block consult the manual.
