Obigibo Posted May 16, 2024 Share Posted May 16, 2024 I have a Helix LT and soley use snapshot mode for my band. Different present for each song, and different snapshots for the parts of the songs that change multiple parameters. Due to the fact i play the bass guitar and have a bass path as well as two 'guitar' paths from it utilising pitch shifters, I use a lot of the blocks on the Helix LT, as well as a lot of DSP with 3 amp blocks running. I also sometimes feel i need more footswitches for snapshots within a song. So my question is, is it possible to control a separate midi connected HX effects with my Helix LT, but to do so within snapshot mode? Im aware I could just have an FX loop block in my signal path on the LT, and sit the HX in that loop, causing it to come on with the pre-programmed effect running, and this would all be snap-shottable in the regular way, turning the FX loop block on and off. But can I go further...?: Can I have my Snapshot on the LT trigger a snapshot within the HX? Could I expand the 8 snapshots I run in a preset in the LT to utilise the DSP and 6 footswitches on the HX to essentially have 12 snapshots, changing blocks and parameters on both machines with one press on either the LT or the HX - will they talk both ways? Could a preset change on the LT change a preset on the HX? Would love to know what the midi possibilities are here with running two units, and what level of control each could have of the other. Bear in mind that for my performance set up I will only ever be in Snapshot mode on the main Helix LT, so the Midi messages it sends need to be programmable to a snapshot on that unit. Many thanks for your wisdom and insights! Dan Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 16, 2024 Share Posted May 16, 2024 In Command Center (Stomp mode) you can send MIDI signal. So AFAIK, that's how you should do it--basically mirror your snapshot layout, and add CC messages. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 17, 2024 Share Posted May 17, 2024 To change a Snapshot on the HXFX requires two messages - Preset# (message 1) and CC#69 + VALUE = 0-3 (Snapshots 1-4). Since a single FS in Stomp Mode can only send one message at a time you would need to trigger a Snapshot on the LT whose Instant Commands are set to send both messages: IC#1 = HXFX Preset# IC#2 = CC#69 + VALUE If you only need the HXFX Snapshots that are in ONE HXFX Preset you can set the LT Preset's default Snapshot's IC1 to send the HXFX Preset# so that it's called when the LT's Preset loads, then use single Stomps to call the HXFX SS#s. In this way the LT Preset can call any HXFX Preset from its 8 Snapshots and any HXFX Snapshot from those Presets using the LT's Stomps. Don't forget to turn OFF "MIDI PC SEND" in Global Settings on the LT to prevent the LT from sending its DEFAULT PC# when you load a preset. Attached is an example Preset. It assumes that the HXFX is on the same MIDI Channel as the LT BASE Channel. Obgibo.hlx 1 Quote Link to comment Share on other sites More sharing options...
