guitarbloke1980 Posted June 18, 2024 Share Posted June 18, 2024 I've got an HX Stomp and would like to use my Boss FS-5U to give me a 3db boost - is this possible? I'm not really sure how to set it up. I already have a simple 2-button latching Mosky switch which is setup to activate the tuner and to bank up though the presets - that was pretty easy to set up, but I can't seem to fathom out how to give myself a simple volume boost using the Boss FS-5U. Also, the FS-5U is a momentary switch - will this be a problem? Any assistance would be really appreciated! Thank you in advance Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 18, 2024 Share Posted June 18, 2024 Should be no problem. You can use a gain block, set it to +3db and Bypass Assign it to FS4. Or Controller Assign any Level / Gain / Volume parameter that is suitable for your application to FS4. You need to set Global Settings: Preferences -> EXP/FS Tip to FS4 Preferences -> Tip Polarity to Normal (depends on the polarity switch of the FS-5) Footswitches -> FS4 Function to Stomp4 Connect the FS-5U with a simple TS cable to the footswitch input. 1 Quote Link to comment Share on other sites More sharing options...
guitarbloke Posted June 21, 2024 Share Posted June 21, 2024 On 6/18/2024 at 5:26 PM, Schmalle said: Should be no problem. You can use a gain block, set it to +3db and Bypass Assign it to FS4. Or Controller Assign any Level / Gain / Volume parameter that is suitable for your application to FS4. You need to set Global Settings: Preferences -> EXP/FS Tip to FS4 Preferences -> Tip Polarity to Normal (depends on the polarity switch of the FS-5) Footswitches -> FS4 Function to Stomp4 Connect the FS-5U with a simple TS cable to the footswitch input. Arrgh can't believe I didn't even think to try a gain block - Duh! Thank you - I'll give that a shot! Quote Link to comment Share on other sites More sharing options...
AshleyRichardR3 Posted June 22, 2024 Share Posted June 22, 2024 I have a helix and want to use it sometimes with an amp speaker combo. I was looking at line 6 amps. Does anyone recommend a amp with speakers for the full helix. Quote Link to comment Share on other sites More sharing options...
