saneff Posted September 24 Share Posted September 24 Each time it blinks (HX Stomp XL)it makes a little faint beep or light noise through the PA. It happened at band practice last night. I am not sure if it's coming through my amp (it's mic'd into the PA) or if it's some sort of interference. Anyone had this issue and know how to fix? Quote Link to comment Share on other sites More sharing options...
ricstudioc Posted September 24 Share Posted September 24 Sorry, no immediate solution but - Glanced at the manual, apparently in the Global/Footswitch menu you have an option to change the Tap function to Bypass. I'd assume that would stop the blinking, and probably set the light to one of two states- lit/unlit. This would at least let you determine if one state or the other is causing the noise, or switching between the two. While we're waiting for a solution to be offered, this seems at least a usable diagnostic. Best I got - there are some great folks 'round here, I'm sure the answer is out there. Quote Link to comment Share on other sites More sharing options...
yalyari Posted September 24 Share Posted September 24 Had similar issue when I daisy-chain power between HX Stomp (not XL) and Line6 G75 wireless receiver. Do you share HX Stomp XL power with any other pedal? My solution was to use isolated power to each pedals. Quote Link to comment Share on other sites More sharing options...
saneff Posted September 26 Author Share Posted September 26 On 9/24/2024 at 7:08 PM, yalyari said: Had similar issue when I daisy-chain power between HX Stomp (not XL) and Line6 G75 wireless receiver. Do you share HX Stomp XL power with any other pedal? My solution was to use isolated power to each pedals. The Stomp XL is alone with no other pedals right now. I was using a wireless to my guitar though. It just hit me I wonder if it could be coming from that? Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 26 Share Posted September 26 As an experiment: disable the tap tempo light. Do you still get that noise? Quote Link to comment Share on other sites More sharing options...
