jolach Posted October 28, 2024 Share Posted October 28, 2024 Hi, on the HXFX when I want expression control and assign a parameter, say "Time", in a digital delay, I press "Learn" and the Expression1 pedal is assigned to "Time" with the values 0-8000 miliseconds. Because I don't want the whole range, I then have to menu dive and change the min (heel) value to 300 and the Max (toe) value to 700. This takes a LOT of turning on dials. This bugs me no end and is a flow killer, when on the M9 the same excercise could be accomplished in 3 seconds, using the same expression pedals. Am I overlooking something? Could'nt find it in the manual. I have Expression pedal 2 assigned to volume only, on the looper. Thanks in advance for your inputs! HXFX firmware 2,5 Quote Link to comment Share on other sites More sharing options...
theElevators Posted October 28, 2024 Share Posted October 28, 2024 Well, first of all if you are on 2.5, you are around 5 years behind... The experience has been vastly improved with the encoders acting faster if you give it a spin. Also, you can do this a lot easier in HX Edit. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 28, 2024 Share Posted October 28, 2024 On 10/28/2024 at 9:26 AM, jolach said: This bugs me no end and is a flow killer, when on the M9 the same excercise could be accomplished in 3 seconds, using the same expression pedals. Hi, Update your firmware to the latest version and use Hx Edit to speed up the editing process. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
jolach Posted October 30, 2024 Author Share Posted October 30, 2024 Thanks guys, this was helpful, firmware update helped the encoder spin speed. It didn't simplify expression pedal assignment though. When I told the user of the pedal (previous M9 user) "use a computer" she laughed and replied, I did'nt buy iRig, did I? 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted October 30, 2024 Share Posted October 30, 2024 use HX Edit. It takes seconds to assign an EXP pedal. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 31, 2024 Share Posted October 31, 2024 On 10/30/2024 at 9:19 PM, jolach said: Thanks guys, this was helpful, firmware update helped the encoder spin speed. It didn't simplify expression pedal assignment though. When I told the user of the pedal (previous M9 user) "use a computer" she laughed and replied, I did'nt buy iRig, did I? Hi, again. Are we actually giving you answers to relay to a third party? I also re-read your initial post where you mentioned using the Exp pedal to edit on the M9. Hmm… is this what you mean? You could also tell your friend - “No, she didn’t buy an iRig”, but it’s a big help and a lot quicker to modify stuff with HX Edit. Also - see page 13 of the HX Effects 3.0 Owner’s Manual > Hands-Free Editing (Pedal Edit) Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
