xxxsovic Posted October 28 Share Posted October 28 Hello. Please help with snapshots. In snapshots, I can only bypass blocks, but if I change the parameter of the amp block, for example. It changes automatically for all snapshots of the preset. In the manual, it says that I can change the parameters of each block and save for each snapshot. Me but it always changes for all snapshots in the preset. Does anyone know how to do it. Thank you very much. I have the latest firmware 3.71 Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 28 Share Posted October 28 You need to assign the desired parameters to the Snapshot controller. To do that, press and turn the parameter knob quickly. You will see white brackets around the parameter value when properly assigned. 2 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 29 Share Posted October 29 On 10/28/2024 at 3:41 PM, xxxsovic said: Hello. Please help with snapshots. In snapshots, I can only bypass blocks, but if I change the parameter of the amp block, for example. It changes automatically for all snapshots of the preset. In the manual, it says that I can change the parameters of each block and save for each snapshot. Me but it always changes for all snapshots in the preset. Does anyone know how to do it. Thank you very much. I have the latest firmware 3.71 Hi, This is from the official Line 6 tutorial videos. More here: https://line6.com/support/helix-minutes/ Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
