easye921 Posted November 9, 2024 Share Posted November 9, 2024 So recently got a Soldano Astro and I have it hooked up my stomp using 4cm. I have also purchased a Fortin Zuul plus noise gate. It hasn't came in yet, but I was wondering how I should go about hooking it up. Before I decided on using my stomp as my main source of effects, I was going to hook up the zuul first in the chain using 4cm though my Astros effects loop. Is it possible to still hook it up this way? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 9, 2024 Share Posted November 9, 2024 Place it between the guitar and the Stomp Input. This could compromise the Auto Impedance feature, but if you're not using any HXS FX that use <1M Impedance, no loss. OR Place it between the HXS SEND and your amp's Input. You'll need to use the Fortin's FS to toggle it (unless the fortin has MIDI). OR Waste a Block for a second FX Loop. Quote Link to comment Share on other sites More sharing options...
easye921 Posted November 9, 2024 Author Share Posted November 9, 2024 Which effects have auto impedance? I mainly using the the stomp for drive, reverb, delay, and occasionally vibe and chorus. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 9, 2024 Share Posted November 9, 2024 I'd solve it like this: guitar -> Hx input Hx send L -> amp input Hx send R -> Zuul key in amp send -> Zuul in Zuul out -> Hx return Hx out -> amp return Use a TRS -> 2x TS split cable for the Hx send to amp input and Zuul key input. In the patch use an additional Send R block first in the signal path to send the clean key signal. Alternative solution: guitar -> Zuul key in Zuul key out -> Hx input Hx send -> amp input amp send -> Zuul in Zuul out -> Hx return Hx out -> amp return Quote Link to comment Share on other sites More sharing options...
easye921 Posted November 9, 2024 Author Share Posted November 9, 2024 Thanks so much. I've always just used cleans amps and effects to the front of the amp. This is my first time using effects loops. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 9, 2024 Share Posted November 9, 2024 On 11/9/2024 at 10:37 PM, easye921 said: Which effects have auto impedance? I mainly using the the stomp for drive, reverb, delay, and occasionally vibe and chorus. FX with input non 1 MOhm impedance: * Distortion * Bighorn 136k Deranged Master 90k Triangle Fuzz 22k Arbitrator Fuzz 10k Tychoctavia Fuzz 230k Octave Fuzz 230k Industrial Fuzz 10k Hedgehog 230k Scream 808 230k * Wah * Teardrop 90k UK Wah 846 136k * Delay * Elephant Man 90k Cosmos 10k * Modulation * 70's Chorus 22k Courtesan 136k This only matters if you use one of these as the first block in the path. The solution from my previous post (but not the alternative one) lets you use the Hx input with it's impedance switching btw. Quote Link to comment Share on other sites More sharing options...
easye921 Posted November 9, 2024 Author Share Posted November 9, 2024 Thanks. I'm going to try your alternate method when the pedal comes in on Monday. Honestly, the gate on the stomp seems to work decent enough. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 9, 2024 Share Posted November 9, 2024 On 11/9/2024 at 11:00 PM, easye921 said: Thanks. I'm going to try your alternate method when the pedal comes in on Monday. Honestly, the gate on the stomp seems to work decent enough. The HX gate does work great, but it doesn't have a key input like the Zuul. That makes the Zuul the better solution because you can put it after the preamp of your amp while triggering it with your clean guitar signal. Quote Link to comment Share on other sites More sharing options...
