vc027708 Posted November 17, 2024 Share Posted November 17, 2024 I'm relatively new to the Midi game for controlling my HX Stomp. I've run in to a issue I can't seem to quite figure out. I'm using a WIDI Master and MIDI Designer on my iPad to do some basic control. What I'd like to do is use a slider on MIDI Designer to control the Output Level of a given snapshot. However, controlling the output isn't my problem. What I want to do is send the current output level value over midi to my iPad when I change the snapshot so that I don't have a drastic change when I first touch the slider. For example, if my Output Level is set to 0dB on my snapshot and the value on my slider is already at 120, as soon as I touch the slider, the output level will jump to whatever dB corresponds to a midi value of 120. I know I can send a specific value to my iPad using an Instant command. I just can't figure out how to "Read" the current value into the midi command before sending it. Hopefully this makes sense. I don't have an expression pedal so I can't control it that way. I'm open to other ideas on how to control this as well. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 17, 2024 Share Posted November 17, 2024 If MIDI Designer can receive MIDI and assign an incoming CC/Value to that specific slider, then you need to determine the MIDI CC and Value that results in 0db on the slider, then assign an IC to send that CC/Value. EX: Slider CC = X; CC Value Y = 0db; IC1 MIDI CC = X with Value Y EDIT: You might still get a momentary volume spike because MIDI transmission is subject to a small amount of latency. Only way to know is to try it. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 18, 2024 Share Posted November 18, 2024 Don't use Output Level in the patch. Manipulate it exclusively via MIDI. Done. Quote Link to comment Share on other sites More sharing options...
