RyanLewis1984 Posted November 30, 2024 Share Posted November 30, 2024 Hi guys. I'm running my Helix with an external amp/cab via the 4 cable method and I'm looking to use the gain from the amp (with a Helix overdrive) but switch to a Helix preamp (most likely JC120 or Fender style) with Chorus for the cleans and bypass the preamp of my 6505. Might be worth mentioning I still need to engage the fx loop (with delay/reverb/EQ) with the gain channel for leads. Apologies if already posted but struggling to find a way to do this. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 30, 2024 Share Posted November 30, 2024 Use a preamp and an fx loop block in series in your patch. Engage Stomp Mode. Bypass assign both blocks to the same foot switch. Bypass one of the blocks manually so that one is bypassed while the other isn't. Done. 1 Quote Link to comment Share on other sites More sharing options...
RyanLewis1984 Posted November 30, 2024 Author Share Posted November 30, 2024 @Schmalle I'd better get reading the manual then. Didn't realise I understood so little about Helix! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 30, 2024 Share Posted November 30, 2024 Reading the manual is a very good idea. It was written for you to get the most out of your Helix. Here is a video that shows how you can build an A/B foot switch: 1 Quote Link to comment Share on other sites More sharing options...
