Dueler Posted 8 hours ago Share Posted 8 hours ago Ok, I just ordered a L6 HX Effects. So far so good. One thing I missed is because the output of the HX will go direct into the PA and with no amp models on board it will sound flat. Ok, L6 seems to have me covered with the Helix Native. Alright, so far so good. Now I need to know if Helix Native will run on my new Samsung Galaxy Tab A9+ and how does it interface with my HX Effects. In short, how does all this stuff blend together harmoniously? BTW, you will be conversing with an absolute newbie. :) Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted 5 hours ago Share Posted 5 hours ago Are you using an amp/cab of any sort, physical or virtual? Helix Native can exchange presets with the HX FX through HX Edit but doesn’t not connect to Helix Native. I doubt that Helix Native will run on your Galaxy tablet but I hope I’m wrong on that. In order to use Helix Native you will need a DAW (audio recording program). Do you have one? To use Helix Native for playing live you will also need an audio interface. Do you have one? HX FX is not one. Also for playing live it needs to work in real time but it involves latency. It’s not recommended. Helix Native is designed for the recording studio, not for live play. Tell us more about your physical setup and your hopes, intentions, and expectations. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 3 hours ago Share Posted 3 hours ago For what you want to do you should just turn it around (hope you bought it somewhere with a good return policy) and swap it for an HX Stomp. If swapping it is not an option, another relatively inexpensive rig would be to add a ToneX1 in the FX Loop of the HXFX. Stores 20 amp captures (three at a time active), thousands more available online (free and paid), and doubles as an AI. 1 Quote Link to comment Share on other sites More sharing options...
