Philipozz Posted January 31 Share Posted January 31 I use an Ampero controller to switch presets on both my amp and HX One via MIDI with a series of messages. My problem is that the ability to use the flux (both via the onboard switch and MIDI) disables when I press a button that calls the same preset that is already loaded. This also locks the preset from having parameters edited through the knobs. If I want to use flux or edit the preset, I have to pick another and then go back again. I tried finding an explanation in the manual and I doubt this behavior is intentional from L6. There are some less pretty ways that I can get around this, like making multiple presets of the same effect or to make a dummy preset that is called between calling the same preset again, but these all ruin the flux by changing the settings instantly. My wishes/suggestions: That the HX One will ignore the PC command if the currently loaded preset is called again and nothing is changed. If something has changed: Reload the preset. The ability to actively change the flux setting to high or low instead of just toggling. Another question: How long does it take to load a preset? I tried making a series of commands to my amp and the HX One where the preset will be loaded and flux being toggled immediately afterwards. I didn't get it to work when doing it as a series of commands, but I could select the preset and then toggle flux. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 31 Share Posted January 31 Are you running the latest firmware? I know it fixed a bug involving Flux but I don’t know if it will fix your issue. Worth a try if you’re out up to date. Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted Sunday at 02:49 AM Share Posted Sunday at 02:49 AM I have this same issue. Knobs are locked after loading the same preset twice. And if I try changing Presets via MIDI PC immediately followed by a CC4 message to toggle an effect OFF, the CC message is never processed. MIDIOX confirms my MIDI controller is sending both messages. If I command both messages, and the preset doesn't need to change, the CC4 message gets through. Quote Link to comment Share on other sites More sharing options...
kwells1204 Posted Monday at 02:18 AM Share Posted Monday at 02:18 AM I am using the latest firmware 3.81.00. Quote Link to comment Share on other sites More sharing options...
