Modalguru Posted 13 hours ago Share Posted 13 hours ago Hi there, my first post in this forum. Thanks for reading! There's no output form the Stomp when I use the cabs 1x12 Epicenter, 2x15 US Dripman, 4x10 Ampeg Pro and 6x10 Cali Power . I did a reset of the unit and restored from backup. Firmware is 3.80. Any suggestions? Thank you! Quote Link to comment Share on other sites More sharing options...
datacommando Posted 7 hours ago Share Posted 7 hours ago On 2/1/2025 at 10:14 AM, Modalguru said: Hi there, my first post in this forum. Thanks for reading! There's no output form the Stomp when I use the cabs 1x12 Epicenter, 2x15 US Dripman, 4x10 Ampeg Pro and 6x10 Cali Power . I did a reset of the unit and restored from backup. Firmware is 3.80. Any suggestions? Thank you! Hi, When seeking assistance from Forum users it's a really good idea to supply as much information as possible, simply saying there is no output is not really enough. What are you playing through and monitoring from? O.K. I’m guessing you’re a bass player, as those cabinets are listed as bass units. Now, you say that there is no output when using those 4 specific cabs, therefore, I have to ask, does this mean that you can still get audio output if you change the cab to a different model? Also, does this mean that you have used these cab models previously and they did work? Is this issue only with the cab blocks you mention or if you use an Amp+Cab block do they work then? Are all other Amp, Cab and FX functioning as expected? You really need to be more specific in describing the issue you’re having. With a situation such as this, it is a good idea to save/export the problem presets as .hlx files and then upload them here. This would allow other users to load them up to see if they encounter the same thing happening. This will help in trying to troubleshoot these things, to see if it is a bug in the software, or a hardware issue. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 6 hours ago Share Posted 6 hours ago They're working for me. Strange that it should be only those three cabs. Same problem on a NEW preset? Which reset did you do? If you did the full reset (2+3) I would reinstall the FW. If that doesn't work contact support. 2 Quote Link to comment Share on other sites More sharing options...
Modalguru Posted 5 hours ago Author Share Posted 5 hours ago On 2/1/2025 at 5:47 PM, datacommando said: Hi, When seeking assistance from Forum users it's a really good idea to supply as much information as possible, simply saying there is no output is not really enough. What are you playing through and monitoring from? O.K. I’m guessing you’re a bass player, as those cabinets are listed as bass units. Now, you say that there is no output when using those 4 specific cabs, therefore, I have to ask, does this mean that you can still get audio output if you change the cab to a different model? Also, does this mean that you have used these cab models previously and they did work? Is this issue only with the cab blocks you mention or if you use an Amp+Cab block do they work then? Are all other Amp, Cab and FX functioning as expected? You really need to be more specific in describing the issue you’re having. With a situation such as this, it is a good idea to save/export the problem presets as .hlx files and then upload them here. This would allow other users to load them up to see if they encounter the same thing happening. This will help in trying to troubleshoot these things, to see if it is a bug in the software, or a hardware issue. Hope this helps/makes sense. Thanks for your reply! After 36yrs on the guitar I've lost my treble ;-) Those cabs don't work when using the amp+cab block, too. All other amp, cab and fx work properly, but I haven't used amps and cabs much. Most of the time I went with the Noble preamp model. I've attached that preset. ChorusAguilar.hlx 1 Quote Link to comment Share on other sites More sharing options...
Modalguru Posted 5 hours ago Author Share Posted 5 hours ago On 2/1/2025 at 6:01 PM, rd2rk said: They're working for me. Strange that it should be only those three cabs. Same problem on a NEW preset? Which reset did you do? If you did the full reset (2+3) I would reinstall the FW. If that doesn't work contact support. Thanks for your reply! I did the 3 knob reset only. Cheers! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 4 hours ago Share Posted 4 hours ago On 2/1/2025 at 11:51 AM, Modalguru said: Thanks for your reply! I did the 3 knob reset only. Cheers! Cab in your preset works fine on my HXS. Try my previous suggestions. 1 Quote Link to comment Share on other sites More sharing options...
Modalguru Posted 4 hours ago Author Share Posted 4 hours ago On 2/1/2025 at 8:29 PM, rd2rk said: Cab in your preset works fine on my HXS. Try my previous suggestions. Thank you very much! Quote Link to comment Share on other sites More sharing options...
