kenmac1 Posted February 11 Share Posted February 11 My system refuses to let me download 3.80, or skip over to 3.82. I've now wasted hours trying over and over to download / install these files, but it fails to download. I've rebooted the internet, which is working fine anyhow. Swapped the USB lead, to try and eliminate the possibility of these links being faulty, but it still refuses to play the game. Is there a way to download the files to my computer without connecting the Helix, then attach the Helix to transfer the files once they are on my system? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted February 11 Share Posted February 11 Your screenshots look like your Mac is running a MacOS version that is no more supported. HX Edit 3.80+ requires Catalina. But fear not, an intrepid fellow forum member has already figured out a hack that works: On 2/11/2025 at 1:43 PM, kenmac1 said: Is there a way to download the files to my computer without connecting the Helix, then attach the Helix to transfer the files once they are on my system? You can still use the Line 6 Updater and download and install the new firmware manually: https://line6.com/software 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 11 Share Posted February 11 On 2/11/2025 at 12:43 PM, kenmac1 said: My system refuses to let me download 3.80, or skip over to 3.82. I've now wasted hours trying over and over to download / install these files, but it fails to download. I've rebooted the internet, which is working fine anyhow. Swapped the USB lead, to try and eliminate the possibility of these links being faulty, but it still refuses to play the game. Is there a way to download the files to my computer without connecting the Helix, then attach the Helix to transfer the files once they are on my system? Hi, When all else fails, this has usually worked for folks having installation issues. Remember, this was put together a few years back now, so any reference to version numbers will need to be substituted with the latest versions. Trust us, this usually works. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted February 12 Author Share Posted February 12 On 2/12/2025 at 7:08 AM, datacommando said: I am actually Running Cataiina 10.15.7. but I will give this a go in the morning. Cheers Hi, When all else fails, this has usually worked for folks having installation issues. Remember, this was put together a few years back now, so any reference to version numbers will need to be substituted with the latest versions. Trust us, this usually works. Hope this helps/makes sense. On 2/11/2025 at 10:04 PM, lou-kash said: Your screenshots look like your Mac is running a MacOS version that is no more supported. HX Edit 3.80+ requires Catalina. On 2/11/2025 at 10:04 PM, lou-kash said: But fear not, an intrepid fellow forum member has already figured out a hack that works: You can still use the Line 6 Updater and download and install the new firmware manually: https://line6.com/software G'day Lou, I am running Catalina 10.15.7, but the updater thing below may work, so I will give that a shot in the morning. Cheers Quote Link to comment Share on other sites More sharing options...
lou-kash Posted February 12 Share Posted February 12 On 2/12/2025 at 2:44 PM, kenmac1 said: I am running Catalina 10.15.7 Hm… then it should actually work out of the box. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted February 13 Author Share Posted February 13 I would have hoped so, but obviously not for me. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted February 13 Author Share Posted February 13 On 2/12/2025 at 7:08 AM, datacommando said: Hi, When all else fails, this has usually worked for folks having installation issues. Remember, this was put together a few years back now, so any reference to version numbers will need to be substituted with the latest versions. Trust us, this usually works. Hope this helps/makes sense. I have just attempted this, and the computer is telling me that the updater software needs to be updated, so it will not install on my Mac. Without the updater install, this thing is dead in the water, again / still. Quote Link to comment Share on other sites More sharing options...
kenmac1 Posted February 13 Author Share Posted February 13 Finally seems to be installing. Had to go via a backdoor route to make the software install. Lots of screwing around, multiple failed attempts but red line on mac screen counting through, , and update message on the Floor unit. Cheers Groovers, and Gurus. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 13 Share Posted February 13 On 2/13/2025 at 5:35 AM, kenmac1 said: I have just attempted this, and the computer is telling me that the updater software needs to be updated, so it will not install on my Mac. Without the updater install, this thing is dead in the water, again / still. Ah, yes - the Apple Gatekeeper jumping in whenever it thinks it sees a threat. Bypass the damned thing! This is fully documented in the “Helix/HX Update Doesn’t Work? Look Here!” link that I posted earlier. I even put a link back to the Apple Support page regarding the Apple Security issues. Just in case anyone else missed it:- https://support.apple.com/en-us/102445 Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
