joeloduca Posted April 21 Share Posted April 21 Greetings all, I own 2 helix effects, a floor and a stomp. On one of them (STOMP), I've kept an extensive list of favorite effects that I commonly use. I configure both devices with HXedit under windows. Much to my surprise, it looks like the favorites are stored with the DEVICE, not the PC and HXedit. Reason I say that is when I patch in the other helix device (Floor) to my pc editor, I do not get the (STOMP) favorites. Is it possible to access STOMP favorites on my helix FLOOR? Thanks ! Joe Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 21 Share Posted April 21 You’re correct. Everything is stored on the device(s). HX Edit does not have a local copy of any data other than a single edit buffer for the active preset. To answer your question the HX Edit manual says this: The HX Edit application supports the use of multiple-connected Helix/HX devices simultaneously, where each device displays its own full application window. The separate windows can be resized and/or positioned on your screen independently, making it easy to reference and edit presets and settings, as well as copy presets and IRs between the multiple USB-connected devices. Please also see “GUI Overview” on page 9. TIP: You can also use the Copy and Paste commands or drag and drop to copy a block and its current settings from one HX Edit device window to another! To access the separate application windows for each connected device, simply go to the HX Edit Devices menu, select the desired device to display, and bring its HX Edit window to the foreground—a checkmark at the left of a device here indicates the device window that is currently in the foreground. If any of your devices become disconnected, its entry within this menu displays “Not connected” to indicate this. Quote Link to comment Share on other sites More sharing options...
