tabqwerty2 Posted June 14 Share Posted June 14 And also have an EQ and reverb (on the HX Effects) after the preamp section on my amp at the same time? Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 15 Share Posted June 15 On 6/14/2025 at 11:33 PM, tabqwerty2 said: And also have an EQ and reverb (on the HX Effects) after the preamp section on my amp at the same time? Hi, There are 3 other Noise Gates available as blocks in the Dynamics section of FX, they are the regular Noise Gate, the Hard Gate and the Horizon Gate, which you can add to the signal path wherever you may need it. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
tabqwerty2 Posted June 15 Author Share Posted June 15 On 6/14/2025 at 7:43 PM, datacommando said: Hi, There are 3 other Noise Gates available as blocks in the Dynamics section of FX, they are the regular Noise Gate, the Hard Gate and the Horizon Gate, which you can add to the signal path wherever you may need it. Hope this helps/makes sense. I don't know how to rewire 4-cable method and the internal signal flow to accommodate an external pedal is what I'm asking. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 15 Share Posted June 15 Guitar>HXFX Input>Noise Gate>FX Loop 1 Block>FX Loop 1 SEND>External Effect Input>External Effect Output>Amp Input>Amp Send> FX Loop 1 RETURN>Other Helix FX>HXFX Out>Amp RETURN You might want to have a look at the manual, there's detailed instructions and diagrams. 1 Quote Link to comment Share on other sites More sharing options...
waymda Posted June 15 Share Posted June 15 On 6/15/2025 at 3:18 PM, rd2rk said: You might want to have a look at the manual, there's detailed instructions and diagrams. Do what, at what? It has what? If I'm finding the constant questions about what is or isn't in the Stadium, requests for features, formats, new versions and (updates?) inane - I'm not sure how I'll go once its released and the forums/fartbook become a cesspit of RTFM questions. A few more months to train my eyes to roll 360 degrees and my fingers to keep off the keyboard. :) 2 Quote Link to comment Share on other sites More sharing options...
