RD1967 Posted July 27, 2025 Share Posted July 27, 2025 So I just updated to the latest Helix version from the previous one and every user preset I import has the same exact settings and my preset seems to be gone even though it's uploaded via edit. Is there something I did wrong? This has never happened before. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 27, 2025 Share Posted July 27, 2025 Describe the update procedure you used Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 28, 2025 Share Posted July 28, 2025 On 7/27/2025 at 7:40 PM, RD1967 said: Is there something I did wrong? Hi, Sorry, we’re not psychic in here. We don’t know if you did something wrong, unless you actually explain what you did? Needless to say, there are a set of rules that should be followed, and you can find them here. Note: the really important things are that you should be using HX Edit 3.82, and after updating, you have performed a Factory Reset on your hardware unit, then you can restore from the backup. As usual, when weird stuff happens, perform a factory reset, and if that doesn’t clear the issue, reinstall the firmware. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
RD1967 Posted July 28, 2025 Author Share Posted July 28, 2025 On 7/27/2025 at 4:50 PM, silverhead said: Describe the update procedure you used I backed up my presets then updated Helix edit first. After "edit" was updated I turned on the Helix and opened edit and it let me know there was an update. I went through the prompts step-by-step like I've always done in the past. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 28, 2025 Share Posted July 28, 2025 That's the correct procedure. Have you tried restarting your computer after the update? Quote Link to comment Share on other sites More sharing options...
