matsraknerud Posted July 30, 2025 Share Posted July 30, 2025 Hi. Without any tempo syncing from external device, is there a way to get effects to work in tempo? I often program one song per preset. And snapshots per song section. This way I can easily get delay times dialed to the tempo for each song. If I want to. The problem appears if I want a envelope effect or tremolo to work with the tempo of the song. I’ve heard that with the H9 you can program the effect to let’s say 130bpm, and with just one hit on the footswitch on the downbeat you are now locked in. For as long as the whole band stays on 130bpm. If you start to drift a little you could just hit the footswitch again. I haven’t found a way to do this on Helix. Does anyone know if it’s possible? I know I can just tap multiple times. But I don’t love the idea of tapping tempo while playing. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 30, 2025 Share Posted July 30, 2025 No. Quote Link to comment Share on other sites More sharing options...
matsraknerud Posted July 30, 2025 Author Share Posted July 30, 2025 Ok. thanks ✌️ Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted July 30, 2025 Share Posted July 30, 2025 On 7/30/2025 at 7:15 PM, matsraknerud said: I’ve heard that with the H9 you can program the effect to let’s say 130bpm, and with just one hit on the footswitch on the downbeat you are now locked in. For as long as the whole band stays on 130bpm. If you start to drift a little you could just hit the footswitch again. How is that supposed to work? I mean, how is hitting that switch again syncing with a new tempo? Quote Link to comment Share on other sites More sharing options...
matsraknerud Posted July 30, 2025 Author Share Posted July 30, 2025 On 7/30/2025 at 10:32 PM, SaschaFranck said: How is that supposed to work? I mean, how is hitting that switch again syncing with a new tempo? If it’s on a preset that’s saved with a certain bpm value, then it’s only a case of moving the downbeat to a different point. And that is possible with one hit. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted July 30, 2025 Share Posted July 30, 2025 So it's kinda like restarting the waveform of whatever modulation it might be? Quote Link to comment Share on other sites More sharing options...
matsraknerud Posted July 31, 2025 Author Share Posted July 31, 2025 On 7/30/2025 at 11:05 PM, SaschaFranck said: So it's kinda like restarting the waveform of whatever modulation it might be? Yupp Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted July 31, 2025 Share Posted July 31, 2025 Ok, gotcha. Yes, that might be useful in some situations. Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 1, 2025 Share Posted August 1, 2025 you can try triplet tempo instead as well. But variable speed tremolo works very well for this exact issue, as I explain in the video. Quote Link to comment Share on other sites More sharing options...
