dishi99 Posted August 25, 2025 Share Posted August 25, 2025 Hi guys, Hope all is well, been trying to connect the hx stomp to my macbook air m1 as an interface to hear audio like youtube through my studio monitors i installed the drivers and updated to last version, set my hx stomp as the device for output on the audio midi interface on the mac. i can only get sound to go out from my headphones jack but no sound comes out from the main outputs, can anyone point me on how to sort it out? any help about this would be greatly appreciated Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 26, 2025 Share Posted August 26, 2025 See Global Settings -> Ins/Outs -> Volume Controls Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 26, 2025 Share Posted August 26, 2025 On 8/25/2025 at 8:55 PM, dishi99 said: Hi guys, Hope all is well, been trying to connect the hx stomp to my macbook air m1 as an interface to hear audio like youtube through my studio monitors i installed the drivers and updated to last version, set my hx stomp as the device for output on the audio midi interface on the mac. i can only get sound to go out from my headphones jack but no sound comes out from the main outputs, can anyone point me on how to sort it out? any help about this would be greatly appreciated Thanks Hi, See page 56 - Ins/Outs, plus page 61 USB Audio. https://line6.com/data/6/0a00051afdda673cccdb61c9c/application/pdf/HX Stomp 3.80 Owner's Manual - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
dishi99 Posted August 26, 2025 Author Share Posted August 26, 2025 thanks guys appreciate your help i tried changing all the ins/outs settings , it didn't effect anything i also looked at the manual on page 61 and it seems i am connecting the hxstomp correctly throuhg the main outputs and even with a blank preste i can't hear nothing unless it's through the headphones jack i noticed i have this error on the system information - disabled software section VCN535JA6Y - com.line6.driver.helix: Version: 1.5.0 Reason: No User Consent Date Disabled: Unknown maybe this could be the issue? the hx stomp does show up on the audio midi settings so i'm not sure it would appreciate any help to solve this thing, i just wanna be able to hear youtube / spotify etc any tip would be appreciated thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 26, 2025 Share Posted August 26, 2025 On 8/26/2025 at 8:56 PM, dishi99 said: would appreciate any help to solve this thing, Hi, I don’t know if this is relevant but did you read this:- I have to say that I am running an older iMac Retina 5k on OS Catalina with Logic Pro X without any issues. At various times over the past 10 years I have also used my Helix floor via USB with GarageBand, Reaper, Ableton, ProTools Lite, among other stuff, and it never misses a beat. If I want to, I can use it to jam along to backing tracks from Music (iTunes), YouTube, or whatever. All this is done in the Audio/MIDI settings, or Logic, etc. - I have even had it working configured with 2 other audio interfaces as an aggregate device, adding extra channels. NOTE: You may want to check your monitor system. In my case, I have my Kali IN-8 v2 monitors hooked up to the XLR sockets on the rear of my Helix. You didn’t make any mention of your studio setup, other than headphones. IIRC, on a Mac your HX device should be a simple plug and play unit, and the driver is only required to use sample rates other than the Line 6 default of 48kHz. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
dishi99 Posted August 27, 2025 Author Share Posted August 27, 2025 hi there aprecciate your feedback my monitors are hooked witih trs on the main outputs from the hx stomp to xlr on my monitors input, i have genelc 8040 active monitors, these cables worked just fine with an rme fireface 800 and a focusrite scarlet , i managed to sort out the driver issue with support and now i can also change sample rate and lower and increase volume on the volume settings on the mac but still no sound comes out the main outputs i agree this should be a plug and play thing, i have no idea why i can't figure it out yet, a setup like this should be super simple i tried making an aggregate device on the audio midi setup but i have no idea what to do with it, anyhow still no sound, if you have any ideas please let me know Any tip would be apprecaited Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 27, 2025 Share Posted August 27, 2025 You don’t mention having checked the Global Settings on your HX stomp as indicated in my earlier reply. Did you do that? Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 28, 2025 Share Posted August 28, 2025 On 8/27/2025 at 5:35 PM, dishi99 said: i agree this should be a plug and play thing, i have no idea why i can't figure it out yet, a setup like this should be super simple Hi, Well, this is weird - if you have used the Global In/Outs of your HXS, available on page 3, then the only options are:- Phones Monitor - Determines which signal(s) are heard from the Phones output. Normally you would set this to “Main L/R.” Volume Control - Determines whether the top panel VOLUME knob controls both the 1/4" main output and headphone output (“Main+HP”) or just the headphone output (“Phones”). When set to “Phones” the 1/4" main outputs remain at unity gain. If your Volume knob is configured to use the phones, then the outputs to your Genlec monitors should be at unity? EDIT: You didn't mention if this issue of just hearing audio via the phone socket, only happens on playback over USB. Does the sound from your HX Stomp play through the monitors if you simply have a guitar on the input If this is not the case, then your best bet is to raise a ticket with Customer Support. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
