How to set Ins/Outs in Global Settings for just using headphones
357mag
If all you're doing is playing through headphones then the only setting that matters is "Guitar In Pad".
If the signal from your guitar is too hot, turn it ON.
If you're using external FX in the Loops then you probably want the SEND/RETURN you're using set to INSTRUMENT for Stompboxes and LINE for Rack Gear if there's no -10db/+4db switch on the device. -10db= stompbox/INSTRUMENT.
