Bug? Copy and paste of blocks with switch assignments screws settings.
stuming
Morning
Not a massive deal but copy and pasting a wah or gain block that has expression pedal latching etc from one preset to another results in the target blocks behaving very weirdly: the new blocks don't turn on with the toe down click on the expression pedal first time, but do the second time, but now the expression pedal is "off" and movement won't be registered.
Deleting the pasted blocks and just creating new ones with the same switch assignments works fine.
There you go.
On 11/27/2025 at 1:16 AM, stuming said:
Morning
There you go.
stuming,
Are you saying you have a specific setting on a wah block or a gain block which you'd like to have in various presets as you create additional presets over time?  Have you tried creating a custom template which you can load with those specific settings and seeing if the settings behave as expected using your custom template as a new preset starting point?  I only ask because I was reading somewhere in the manual concerning default exp settings and how they are assigned in a new blank preset.  I have yet to fully memorize the manual as I am slowing re-reading as I use the Stadium as a sandbox.
Or am I way off base?
jpd
