lespaulphase90 Posted November 29 Share Posted November 29 I got all of my presets and setlists off of my Helix LT. Updated Stadium. Uninstalled HX Edit and Reinstalled. I downloaded the Stadium Driver. I used two different USB cords. My computer/HX Edit won't recognize the Stadium. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 29 Share Posted November 29 The editor for Stadium device es is called Helix Stadium, or HX Edit. Try downloading and installing that. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted November 29 Share Posted November 29 On 11/28/2025 at 5:05 PM, lespaulphase90 said: I got all of my presets and setlists off of my Helix LT. Updated Stadium. Uninstalled HX Edit and Reinstalled. I downloaded the Stadium Driver. I used two different USB cords. My computer/HX Edit won't recognize the Stadium. lespaulphase90, As silverhead stated you need to use the Helix Stadium XL down of "Helix Stadium. HX-Edit does not work. I've added a screen shot. I was little confused at first myself. You will only connect via Wi-Fi on the same network for creation on the Stadium. You will not use the USB cord for creating presets and setlists for now. If you do need to use the USB cord it would be for updating firmware in a pinch or connecting to your DAW; the reason for the Stadium drivers. I had to use a USB-C to USB-C cord as nothing else would work; and that was after I read the manual. I chose to uninstall everything "old Helix". The software, the HX Edit, the drivers, etc. I even removed the uninstall module(s). Hope this helps. jpd I 1 Quote Link to comment Share on other sites More sharing options...
mkopec Posted yesterday at 12:16 PM Share Posted yesterday at 12:16 PM On 11/28/2025 at 5:05 PM, lespaulphase90 said: My computer/HX Edit won't recognize the Stadium My issue was auto connecting with Stadium. I had to input the device IP each time. The fix was to uninstall/reinstall, and now it is auto-connecting. Quote Link to comment Share on other sites More sharing options...
