anthowaters Posted December 29, 2025 Share Posted December 29, 2025 I tried to import backing track created on cubase in wave format 24 bit 44100 khz, but the software doesn't allow me to drop the file. Did I miss something? 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2025 Share Posted December 29, 2025 WAV format of 24 bit 44100 khz is OK. How long is the stem? The maximum is 13 minutes playing time. Have your tried using other stems to test? Make sure you are using compatible versions of Stadium editor/app and firmware. Quote Link to comment Share on other sites More sharing options...
anthowaters Posted December 29, 2025 Author Share Posted December 29, 2025 The song is 3:50 mn. Tried other files, no success. Both the app and the hardware are ver. 1.2 updated Quote Link to comment Share on other sites More sharing options...
stapani Posted December 29, 2025 Share Posted December 29, 2025 Maybe check your letters? When I changed folder and wav-file name from BÖC to BOC I was able to drop my files. 1 Quote Link to comment Share on other sites More sharing options...
anthowaters Posted December 29, 2025 Author Share Posted December 29, 2025 The file name is hole hearted, so it shouldn't be an issue... Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2025 Share Posted December 29, 2025 Double check the installed versions of the app and firmware. To do so, use the Help-> About tabs in the app. It will display the installed versions of both. What are they? Quote Link to comment Share on other sites More sharing options...
anthowaters Posted December 29, 2025 Author Share Posted December 29, 2025 I solved the problem. Effectively, I changed the name of the file (no space between the words) and it works! Thanx Quote Link to comment Share on other sites More sharing options...
zuccero Posted January 2 Share Posted January 2 hi, I was reading that the helix stadium can do stem separation from wave files.Is this correct? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 2 Share Posted January 2 On 1/2/2026 at 6:49 AM, zuccero said: hi, I was reading that the helix stadium can do stem separation from wave files.Is this correct? A stem file is typically a pre-mixed audio file containing multiple tracks (eg. drums, keyboards, etc.) that can be further processed as a unit. If you mean “Can Stadium extract the original tracks from a stem file and treat them as individual drum, keyboard, etc. tracks” the answer is no. But you can transfer a stem track along with other individual tracks into Stadium to create a Song. However, the stem file remains a single track/unit in Stadium. Quote Link to comment Share on other sites More sharing options...
Wingspinner Posted January 19 Share Posted January 19 Greetings. wav converted to separate stems isn't available yet, but will be in a future update according to the support team. I hope it is in 1.3! Quote Link to comment Share on other sites More sharing options...
H4Z4RD Posted January 31 Share Posted January 31 On 12/29/2025 at 6:21 PM, anthowaters said: I tried to import backing track created on cubase in wave format 24 bit 44100 khz, but the software doesn't allow me to drop the file. Did I miss something? Same here but renaming wont work for me. UPD. But I forgot to rename folder and after that it works OK. So looks like only English letters in route forks fine Quote Link to comment Share on other sites More sharing options...
Echotones Posted February 12 Share Posted February 12 I have the same issue with some backing tracks, I tried to rename them but it still doesn't work Quote Link to comment Share on other sites More sharing options...
jpdennis Posted February 12 Share Posted February 12 On 12/29/2025 at 5:33 AM, anthowaters said: I solved the problem. Effectively, I changed the name of the file (no space between the words) and it works! Thanx anthowaters, Thanks for the update. jpd Quote Link to comment Share on other sites More sharing options...
Echotones Posted February 12 Share Posted February 12 I did the same, it still doesn't work. Quote Link to comment Share on other sites More sharing options...
RG320FA Posted March 3 Share Posted March 3 I did the same, it still doesn't work. Quote Link to comment Share on other sites More sharing options...
franksannowitz Posted March 26 Share Posted March 26 I have the same problem: no import of wav-files in a song is possible (24 bit, 44.100 khz, name of the file is "loop.wav"). I have tried drag and drop and the file browser. Nothing happens. Please help! Quote Link to comment Share on other sites More sharing options...
