claudeu Posted August 20 Share Posted August 20 HX stomp XL+ Expression pedal Boss EV-30: Snapshot 1: Wah block heel down: Wah off. Toe down from 5% upwards: Wah on. Snapshot 2: Wah block isn’t needed (Mix 0% via snapshot) When I switch back from snapshot 2 to snapshot 1, the Wah is switched on in heel down position. How can I fix this. Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 20 Share Posted August 20 You probably have the wah block assigned to snapshots and also control if it's bypassed by using the percentage. Having 2 of these will create a conflict. Remove the snapshot bypass. Leave the percentage-based engagement. Now your wah will always be engaged when after 5 percent, and disengaged when lower than 5 percent. If wah is not needed in one of the snapshots, that's easy: Take the "mix" parameter of the wah and assign it to snapshots. Simply go to the snapshot in question, and set the mix to 0% in that snapshot only. Now the wah can turn on, but you will not hear it, effectively bypassing it. When a block is mixed at 0%, it's the same thing as if it were bypassed. This is how I use the wah, or any other block I need to bypass/unbypass with the wah in certain snapshots only. Works consistently and reliably. I have this one crazy preset where one EXP2 controls multiple different things in each of the snapshots, not just wah, but gain/feedbacker/extra delay/synthesizer/vibrato.... There are also a bunch of toggle settings for bypass behavior, I never trust it (toe down, etc), as I saw some serious problems when it was first introduced. I just use the "toggle" behavior without any issues at all. Quote Link to comment Share on other sites More sharing options...
claudeu Posted August 21 Author Share Posted August 21 Hi, you helpful guy in Texas. You sent me the solution for my longtime problem. Now iI works perfectly. Thanks a lot! 1 Quote Link to comment Share on other sites More sharing options...
