Any way to duck with sidechain from another block?
Aurasphere_au
I spent a couple of hours to try doing this with every conceivable angle including asking chat which was full of rubbish; this is a short piece from the preset
Input >>> Digital delay
         >>>Tape delay with 99% Feedback
The dig delay is the highest priority and I want the signal of it to sidechain the ducking of the tape delay so that as the main delay resolves it reveals the underlying drone of the tape feedback
Ive done this a lot in mixing over the years and thought it should be pretty straightforward for Helix
Am I missing something or it just cant be done?
Cheers
On 8/25/2026 at 2:20 PM, rd2rk said:
IIRC, it's one of the new features of Stadium.
Cool...well thats a shame...I wont be buying anything new for a while...not because I dont want to.
Was an absolute snap in Guitar rig...in fact you could combine it with step sequencers and lfo etc...why they couldnt do a hardware version I dont know but Im not doing software based live again. that 7ms of latency is only small but its a showstopper else thatts where I would be
Here's a suggestion.  You can only do split paths, but it's very tricky.
1. Add a duck'ing reverb block, with mix at 100%
2. Move the block to a parallel path.
3. Now on line 2, what's coming in is your guitar signal, what's coming out is ducking reverb only.
3. Add a sensible amount of delay after that on the same line, a few repeats, not 99%
Now as soon as you stop playing notes, the duck'ing reverb engages, and the signal goes to the delay.
Ducking reverb is sweet.  It lets your entire note ring out, and when you stop playing, it creates this wall of sound.  You need to play around with the pre-delay and feedback parameters.
Duck'ing reverb works great on the Helix, and if you put it in parallel path, you can add a bunch of effects after it, mix it however you want.
If you can't get the duck'ing effect working, if it's not automatically disengaging as you need, you can always assign things to the expression pedal and mix your delay out, or even bypass it.
Not really related, but I crated a preset that creates a synth pad, all using parallel paths.  So you may find it useful how to organize things in all those parallel paths.
  • Thanks 1
GR was never my favorite amp sim, but its routing capabilities were its standout feature.
Also had some crazy effects. I loved the Psyche Delay!
Unfortunately, NI was mainly into synths.
