ezaz Posted August 28 Share Posted August 28 Because I am a JTV89F user in combination with helix stadium Floor, I'm very much waiting for the expand D10. I have a question about the connection cable for D10 with Helix stadium. They say that a CAT6 cable will work. The port on the Helix stadium (looks like VDI port) and the port on the D10 look different, there it seems to be a normal ethernet port. Does anyone know, whether there is a special cable to connect the D10 with the helix stadium? Or will the D10 be delivered with a connectioncable? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 28 Share Posted August 28 A standard VDI cable should work. I say this based on the following info in the D-10 product description found within the Helix Stadium device product description: Variax Digital Interface (VDI), L6 LINK, AES/EBU, and 8-channel optical connectivity…. Connect Variax modeling guitars via VDI… I don’t know if the cable will be included with the D-10 package. Quote Link to comment Share on other sites More sharing options...
adflaker Posted August 28 Share Posted August 28 (edited) The only thing "special" about the port on the stadium is its ability to accept what's called an Ethercon connector (if what you say about using a Cat6 cable is correct). It's basically a latching protective cover that wraps around an ordinary ethernet cable. A regular ethernet cable will still work fine in an Ethercon port. If the D10 doesn't come with a cable, you can either use a regular one or buy a cable with an Ethercon connector on one end and a regular ethernet connector at the other (found one linked below). https://www.markertek.com/product/ec8-rj45-3/laird-ec8-rj45-cat5e-tactical-ethernet-cable-neutrik-ethercon-rj45-to-rj45-black-3-foot?gad_source=1&gad_campaignid=21341166847&gbraid=0AAAAAD_iEPjylN5jY8azIDkX2GOjTSiGP Edited August 28 by adflaker Clarity 1 Quote Link to comment Share on other sites More sharing options...
