MojoAxe Posted September 22 Share Posted September 22 This is not something that I want to do presently, but I’m just wondering if it’s possible to do in the event that a future firmware update has a bug that’s serious enough that I would want to revert back to the previous version. Traditionally, the firmware is downloaded manually to a PC and then installed into the modeler. With the Stadium, there is no downloaded firmware to save to a PC. I assume that I could restore a backup file from a system backup, however that would also restore the presets to back to the date of the backup. Again, this is not something I need to do, but I just want to be prepared in case there’s a bug in a new release gives me a reason to stick with the previous version until it gets fixed. Quote Link to comment Share on other sites More sharing options...
msj12345 Posted September 22 Share Posted September 22 Go the the downloads page. Choose your hardware (Helix Stadium/Helix Stadium XL. Leave Software and OS blank and press Go. You will get to the page with all the Stadium FW versions Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 22 Share Posted September 22 Stadium operates differently re: firmware downloads. You need to use the Line 6 Central app to view and install older Stadium firmware versions. Quote Link to comment Share on other sites More sharing options...
MojoAxe Posted September 23 Author Share Posted September 23 On 9/22/2026 at 7:35 AM, msj12345 said: Go the the downloads page. Choose your hardware (Helix Stadium/Helix Stadium XL. Leave Software and OS blank and press Go. You will get to the page with all the Stadium FW versions That webpage allows you to download older versions of the app for the PC, not the actual firmware for the Stadium unit itself. At the present time, you cannot download Stadium firmware to a PC and then upload it to the Stadium unit. The only way to load firmware is directly from the unit itself via WiFi. If you select "Downloads" from the main menu on the unit, it tells you that you're "Up to date", and it does not give you an option to revert to an older version. I believe that the only way to revert to an older version of firmware might be to restore from a full backup (and I'm not even sure if that will do it). Its highly unlikely, but conceivable that a new firmware release has a significant bug in it. I was just pondering whether or not its possible to go back to a previous version until such bug has been fixed. Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 23 Share Posted September 23 On 9/23/2026 at 8:15 AM, MojoAxe said: … I believe that the only way to revert to an older version of firmware might be to restore from a full backup (and I'm not even sure if that will do it). … The Line 6 Central app allows you to install older firmware versions. 1 1 Quote Link to comment Share on other sites More sharing options...
