jesuscares Posted 10 hours ago Share Posted 10 hours ago Can someone suggest the best way to hook up the H90 with the stadium? I tried routing it via the send & return inputs & it does'nt sound right.Some of the effets of the H90 sounds panned to the right.I dont see a pan option on the fx insert.I have never tried out hooking an external effect via send/return so any info on that would help. Thanks Quote Link to comment Share on other sites More sharing options...
boynigel Posted 1 hour ago Share Posted 1 hour ago On 11/19/2026 at 1:20 AM, jesuscares said: Can someone suggest the best way to hook up the H90 with the stadium? I tried routing it via the send & return inputs & it does'nt sound right.Some of the effets of the H90 sounds panned to the right.I dont see a pan option on the fx insert.I have never tried out hooking an external effect via send/return so any info on that would help. Thanks I use an H90 w/mine too. just out of curiosity, are you controlling it via midi? asking because i currently have an open support ticket w/L6 regarding some midi communications issues that they've acknowledged as legit and are working to fix. Maybe your H90 is getting a pan command in error? if not, see if the panning issue persists outside of the Stadium on another piece of gear if possible? Or maybe do a factory reset on the Stadium, after a backup of course, and see if the problem persists after doing so? Quote Link to comment Share on other sites More sharing options...
