onebass Posted June 3, 2014 Share Posted June 3, 2014 I have the full Dreamstage set up has been perfect (The Bags are poor IMO but thats a different story) In the last two weeks at practice we only use the vocals on input one and the speakers drop out and then pop and come back in, I'm using a Shure Beta 87 Condenser with +48v selected. We have changed leads,Mics and as a last resort switched the mic to another channel and it now works. Which suggests the Mic 1 input is damaged/Faulty or has dirt on the pins/Connectors Any advice? Thanks Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted June 3, 2014 Share Posted June 3, 2014 What is the other I put you switched to? Was it 2 - 6? Or was it 7-12? I am just wondering if it was in the other "group". You can put phantom power on 1-6, or 7-12. Quote Link to comment Share on other sites More sharing options...
Octo777 Posted June 3, 2014 Share Posted June 3, 2014 See my thread for details of a very similar problem.... After several months I diagnosed the fault down to a faulty Multi Socket on that particular input as well as input 6.http://line6.com/support/topic/6559-issue-volume-reduction-on-stereo-grouped-device/ Quote Link to comment Share on other sites More sharing options...
onebass Posted June 4, 2014 Author Share Posted June 4, 2014 What is the other I put you switched to? Was it 2 - 6? Or was it 7-12? I am just wondering if it was in the other "group". You can put phantom power on 1-6, or 7-12. Its No 10 now but I tried a passive mic in No 1 and it still dropped out. Quote Link to comment Share on other sites More sharing options...
onebass Posted June 4, 2014 Author Share Posted June 4, 2014 See my thread for details of a very similar problem.... After several months I diagnosed the fault down to a faulty Multi Socket on that particular input as well as input 6. http://line6.com/support/topic/6559-issue-volume-reduction-on-stereo-grouped-device/ Thanks for the link Its very similar to my problem, quite worrying really for £1.5 k Mixer , Thomann although quite cheap are not great on customer care IMO. Quote Link to comment Share on other sites More sharing options...
bassman24 Posted June 4, 2014 Share Posted June 4, 2014 Just as an idea: Do you have noise gates on your preset for channel one and maybe have it set too high? This was something I was struggeling with at my last gig. Thought 2 Inputs where dead, but afterwards it turned out that the gates were set too high for the channels (where the Setting was just fine from the gig before when I loaded the Setup again for that gig). Anyway: My fault and no Hardware issue on my side. Fortunate enough. Quote Link to comment Share on other sites More sharing options...
onebass Posted June 4, 2014 Author Share Posted June 4, 2014 Thanks I'll check that out, it might be on by mistake but I don't use noise gates at all. Quote Link to comment Share on other sites More sharing options...
onebass Posted June 6, 2014 Author Share Posted June 6, 2014 I checked the noise gates and they are all off, I used Channel one again with a Passive mic and it did the same again swapped to channel 2 and it worked perfectly, So looks like a problem with Channel 1 perhaps a dry solder joint? . The mixer was bought as B Stock so I don't have a warranty and only 11 XLR inputs :( Quote Link to comment Share on other sites More sharing options...
brianj402002 Posted June 6, 2014 Share Posted June 6, 2014 I thought I seen somewhere on here awhile ago about a stuck pin and was fixed using a toothpick...not sure if this is related or not... ***nevermind..it was in the reference that Octo777 listed above*** Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 7, 2014 Share Posted June 7, 2014 The mixer was bought as B Stock so I don't have a warranty and only 11 XLR inputs :( B-stock from Thomann doesn't affect your warranty. Indeed B-stock from any supplier shouldn't affect your warranty. Quote Link to comment Share on other sites More sharing options...
onebass Posted June 11, 2014 Author Share Posted June 11, 2014 B-stock from Thomann doesn't affect your warranty. Indeed B-stock from any supplier shouldn't affect your warranty. Thanks for the reply, I got the mixer from DV247 so its a 12 month warranty, I did email them and they said it was no longer covered, I replied with the 1979 Sale of goods act conditions and they have offered to have it collected FOC and looked at so thats a start, Here's keeping my fingers crossed. Thanks Again. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 11, 2014 Share Posted June 11, 2014 Sorry, I assumed as you'd mentioned Thomann and then B-stock in a separate post that you'd bought a b-stock one from Thomann. Forgive me... :-) Quote Link to comment Share on other sites More sharing options...
