TSMilliner1 Posted June 21, 2014 Share Posted June 21, 2014 Hi, Not sure if this is the same issue described on the 6th string in a different post. I have a jtv-59 (2012) and until recently no issue. Playing the guitar in variax mode through the hd500x and all of the sudden the high e string starts sounding like a "whammy" pedal is switched on. Moving the selector knob to an alt tuning and back fixes the problem. It doesn't I happen frequently, but when it does it is annoying. I am pretty sure this started after the firmware update, and I have reflashed it once which has seemingly helped, but it has happened since. The only other change is that I swapped strings to the new m-steel strings and haven't switched them back to rule that out. Had the guitar in case for about 6 months when my hd500 died, and only recently broke it back out to use with the 500x as I am trying to get back into using different models in my playing. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted June 27, 2014 Share Posted June 27, 2014 I recommend that you make an audio recording of this problem and then open a ticket with LIne6 support and described the problem to them along with the audio recording. They will then be able to help you get to the bottom of it and hopefully resolve it for you. Quote Link to comment Share on other sites More sharing options...
TSMilliner1 Posted July 6, 2014 Author Share Posted July 6, 2014 I found the problem, feel pretty ridiculous. I was using a hd500x tone that I got off of custom tone, and it had an alt. tuning that forced the 6th string down -1 programmed into the settings. For some reason it didn't happen every time, and would sometimes take a minute to kick in when it did. Found out by accident when I started messing with creating my own tones in hd500x software using the JTV models and saw that you could force different string to raise or drop outside of the normal alt tuning modes. Quote Link to comment Share on other sites More sharing options...
