mypods Posted June 11, 2013 Share Posted June 11, 2013 If I change the input to MIC and then change the patch, the HD500 reverts back to the guitar input. Seems that the input is set per-patch and not globallt. This sucks big time for me as I would like to quickly test a bunch of presets with my mic and currently there is no way to do this other than go to the I/O page for each and every patch! Is there a way to enable the MIC globally? Thanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 11, 2013 Share Posted June 11, 2013 Actually, you can change the inputs globally. On the setup screen 3/10, there's a parameter called "inputs setup". If you select "global" here, the way you setup the inputs will override any settings you have saved with your presets. In HD500 Edit, this parameter is up in the upper left hand corner of the screen. Quote Link to comment Share on other sites More sharing options...
mypods Posted June 12, 2013 Author Share Posted June 12, 2013 I went to my HD500 and didn't have this option. Then I noticed that you said "setup screen 3/10" and I only had 9 in total! So I opened up Line 6 Monkey and noticed that I was using the 1.3 firmware and the latest one was 2.10. After upgrading, all's good. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
jws1982 Posted June 13, 2013 Share Posted June 13, 2013 With that firmware update, you also added more amp models too. Quote Link to comment Share on other sites More sharing options...
mypods Posted June 13, 2013 Author Share Posted June 13, 2013 Great! I'm loving the sound of this processor. Not too hot about the interface. After years of using Digitech, this processor's UI seems very counter-intuitive. But it sounds much better than my old Digitechs so it's all good! Quote Link to comment Share on other sites More sharing options...
jws1982 Posted June 13, 2013 Share Posted June 13, 2013 Just takes time. I'm very used to it now, and I like editing on the device better than in the computer software. Never thought I'd be saying that when I first got the unit. Quote Link to comment Share on other sites More sharing options...
