ajgor Posted August 27, 2014 Share Posted August 27, 2014 Hello. I have a Toneport UX1, and would like to buy bass combo of Ampeg. And would like to ask, if it is possible to connect the Line Out of that bass combo to Toneport UX1, and record the bass in that way? Wchich input I should use in my Toneport? The guitar input, or the microphone input? How to do all of that correctly, to get best effect, and not to spoil anything? Greetings. Andrew Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted August 27, 2014 Share Posted August 27, 2014 you can do it... best way depends on your amp... but ideally i would go from a direct out on your amp if available to the mic port.... but you could get workable results from other options as well. Quote Link to comment Share on other sites More sharing options...
ajgor Posted August 27, 2014 Author Share Posted August 27, 2014 In fact, for playing on the scene I have other, professional equipment, but for home playing, I am intend to buy the smallest Ampeg Combo - BA108. For the home work it is enough. It has very good sound, and enough power. And it has Line output. Thank You. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 27, 2014 Share Posted August 27, 2014 If it is Line level out, I would try the Line In on the back. Quote Link to comment Share on other sites More sharing options...
ajgor Posted August 27, 2014 Author Share Posted August 27, 2014 O yes. I forgot about the Line input :) Than You very much. Greetings Quote Link to comment Share on other sites More sharing options...
ajgor Posted September 5, 2014 Author Share Posted September 5, 2014 Well.. So finally I have the Ampeg BA-108 amp in home. Its sound is beautifull. I have plugged the line output of amp into Line input in my Toneport UX-1, and set the Gearbox input to Line 1. All works well. I can record my bass to DAW (Reaper, Ableton Live etc). But I have one more question. Every time, I record something, the sound is affected by the simulated amp, I have set in gearbox, and the tone is different, than the original one from Ampeg Amp. So how to set Gearbox, to get original tone directly from Ampeg, via Toneport to my DAW? Without any ingerention of Gearbox's effects or simulated amps? Greetngs Ajgor Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 5, 2014 Share Posted September 5, 2014 For the record, POD Farm 1.12 replaces Gearbox. In the mixer view of POD Farm you can control what is delivered to Sends 1 thru 4. I think in Gearbox it is send 3 and 4 set to Pre (Can't remember off hand, it's been a while since I used Gearbox). Either way, in your DAW make sure you have allo 4 inputs enabled, then when you arm a track to record, make sure you are selecting the appropriate inputs. Quote Link to comment Share on other sites More sharing options...
