titopizarro Posted April 17, 2015 Share Posted April 17, 2015 Hi Everybody. I solved all my issues downgrading to Mavericks. Now I'm a happy man. Yosemite is not good for Music apps. There are a lot of tutorials online for how to downgrade from Yosemite to Mavericks. I hope helps you. Quote Link to comment Share on other sites More sharing options...
glaucoleone Posted May 15, 2015 Share Posted May 15, 2015 same problem here. Bought Pd hd 500x 1 week ago, and i'm not able to update firmare. Monkey doesn't launch. Yosemite OS what can i do?? thank you Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 15, 2015 Share Posted May 15, 2015 you probably need to try the solution quoted here same problem here. Bought Pd hd 500x 1 week ago, and i'm not able to update firmare. Monkey doesn't launch. Yosemite OS what can i do?? thank you Hello everyone My Spanish is very weak but I do concur that the Avid CoreAudio plug-in installed by proTools causes the problem in my setup as well. I was working on a project today that used a Native Instruments plug-in called Guitar Rig. It would not work in ProTools. When I tried to launch the standalone version is exhibited the same bouncing icon behavior as Monkey does with Yosemite. There is a procedure on the Native Instruments web site that describes how to relocate the Avid CoreAudio plug-in. After a reboot. Both Guitar rig and Line 6 Monkey launched correctly. If you use Avid Hardware - you need this plug-in for ProTools. I use MOTU hardware so when I removed the plug-in, Guitar rig, Monkey and proTools all worked correctly. If you are not using ProTools and you have the problem - you should check all of the software you use for Yosemite Compliance. It may be another package causing the problem. But if you use ProTools this fix may get you going again. I have pasted in the information from the Native Instruments Web Site here below..... Hope this helps Art Braun My NI Application Does Not Launch Under Mac OS 10.10 Yosemite Disclaimer: This article describes the manual uninstallation of a third-party manufacturer component. Native Instruments cannot be held responsible for any damages to your system caused by following these instructions. Products with a hardware dependency, such as MASCHINE, KOMPLETE KONTROL, TRAKTOR, GUITAR RIG, and Controller Editor will not launch when the AVID CoreAudioManager / Drivers are installed under 10.10 Yosemite. In stand-alone mode the application will freeze after launching, in plug-in mode the plug-in validation of the host program will fail, which might crash or freeze the host program or make the plug-in unavailable within the host program. Native Instruments and Avid are working together to resolve this compatibility issue. Follow these step-by-step instructions to temporarily remove the Avid CoreAudio driver in order to allow NI products to run properly under Mac OS 10.10: Open the Finder and locate the following folder: Macintosh HD > Library > Audio > Plug-Ins > HAL Copy the "Avid CoreAudio.plugin" to another location, for example the Desktop. Delete the "Avid CoreAudio.plugin" from the HAL Plug-in folder. Type in the admin password when prompted. Restart your computer. While you still can fully use Pro Tools without the Avid CoreAudio driver, it is not possible to monitor the audio output of any third-party application using your Avid audio interface. If you require this functionality again, you need to move the file back to its original location and restart your computer. In this case, the mentioned NI applications will stop working again. Quote Link to comment Share on other sites More sharing options...
glaucoleone Posted May 15, 2015 Share Posted May 15, 2015 you probably need to try the solution quoted here thank you but it not solve the problem. I'm, not a pro tools user, i use logic Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 15, 2015 Share Posted May 15, 2015 doesn't matter... other software in the referenced HAL folder can cause issues launching monkey... i had the issue and did not have pro tools either... i also use logic.... Quote Link to comment Share on other sites More sharing options...
glaucoleone Posted May 15, 2015 Share Posted May 15, 2015 doesn't matter... other software in the referenced HAL folder can cause issues launching monkey... i had the issue and did not have pro tools either... i also use logic.... IT WORKS!! I had an avid core audio plugin in the HAL folder. I moved it out and now monkey is running! Great! Thank you. Quote Link to comment Share on other sites More sharing options...
spankinharry1 Posted June 9, 2015 Share Posted June 9, 2015 Just starting you are a tool don't follow his instructions it will disable all programs the ability to open ever again Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted June 9, 2015 Share Posted June 9, 2015 it worked... for him.... it worked for me... it's worked for countless others.... it does have risk... the HAL fold (stands for hardware abstraction layer) can hold critical drivers... only remove the avid ones... or other ones that you are familiar with and recognize that you don't need. Quote Link to comment Share on other sites More sharing options...
RioBautista Posted June 21, 2015 Share Posted June 21, 2015 I checked my HAL folder and found NI and M-Audio drivers from my old apps. I removed them but my problem still persists. I guess mine is a bit different. I have no problem starting Line6 Monkey, my problem is that it won't install the drivers and couldn't detect my PODHD500. Quote Link to comment Share on other sites More sharing options...
RioBautista Posted June 21, 2015 Share Posted June 21, 2015 OK, Got mine finally working... I had to use a PC to update the USB Firmware and Flash Memory to the latest versions. Then when I connected back to my Mac OSX Yosemite everything was back to normal. Quote Link to comment Share on other sites More sharing options...
Duke04 Posted August 5, 2015 Share Posted August 5, 2015 Hi guys ! It's late but I met the problem willing to check if my Pocket Pod was up to date ! And Monkey was not, and it said it could install because of the OS X version ... So I read ALL the items of this page ... nothing worked ! So I downloaded the Monkey in the Line 6 support/download page : TADAAA ! No more problem . So ! Enjoy ... Quote Link to comment Share on other sites More sharing options...
ronpdenver Posted October 23, 2015 Share Posted October 23, 2015 I was having similar issues and contacted support. Their response was quick and works great! Here you go: Hi, and we're sorry about the trouble you've run into with your system. Since the release of Apple’s Yosemite OS, we’ve seen a relatively small number of reports that Line 6 Monkey does not open on some systems running Yosemite. This is a system configuration issue whose result affects not only Line 6 software, but possibly other software on a given computer. Please move or delete any .plugin file from the Library/Audio/Plug-Ins/HAL folder, then restart your computer and open Monkey.Please let us know the results.Best regards,JelenaLine 6 Support Quote Link to comment Share on other sites More sharing options...
ajosue89 Posted December 6, 2015 Share Posted December 6, 2015 How is it possible that you guys (Line 6) still haven't fixed this?? There are so many Line 6 tools on my Mac I still can't use because it doesn't matter how many times I uninstall and install Line 6 Monkey it still won't open. Please let me know how I can fix this or when you will finally put out a working update. It's been well over a year. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 6, 2015 Share Posted December 6, 2015 how did you get to this thread and miss the fix... that's long posted.. .and long working..... Follow these step-by-step instructions to temporarily remove the Avid CoreAudio driver: Open the Finder and locate the following folder: Macintosh HD > Library > Audio > Plug-Ins > HAL Copy the "Avid CoreAudio.plugin" to another location, for example the Desktop. Delete the "Avid CoreAudio.plugin" from the HAL Plug-in folder. Type in the admin password when prompted. Restart your computer. How is it possible that you guys (Line 6) still haven't fixed this?? There are so many Line 6 tools on my Mac I still can't use because it doesn't matter how many times I uninstall and install Line 6 Monkey it still won't open. Please let me know how I can fix this or when you will finally put out a working update. It's been well over a year. Quote Link to comment Share on other sites More sharing options...
ajosue89 Posted December 7, 2015 Share Posted December 7, 2015 That might be the fix to a problem but not my problem since I don't have any Avid plug-ins in my computer whatsoever and already deleted anything I didn't recognize from my library folder... Thanks for your "help"? how did you get to this thread and miss the fix... that's long posted.. .and long working..... Follow these step-by-step instructions to temporarily remove the Avid CoreAudio driver: Open the Finder and locate the following folder: Macintosh HD > Library > Audio > Plug-Ins > HAL Copy the "Avid CoreAudio.plugin" to another location, for example the Desktop. Delete the "Avid CoreAudio.plugin" from the HAL Plug-in folder. Type in the admin password when prompted. Restart your computer. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 7, 2015 Share Posted December 7, 2015 remove it even IF you recognize it.... put it on your desktop for restoration later.... perhaps this will allow monkey to open.... unless you have a problem with your computer.... thats the likely issue... they arent going to fix your computer for you. That might be the fix to a problem but not my problem since I don't have any Avid plug-ins in my computer whatsoever and already deleted anything I didn't recognize from my library folder... Thanks for your "help"? Quote Link to comment Share on other sites More sharing options...
vernurban Posted March 20, 2016 Share Posted March 20, 2016 Ok, i also do not have any avid files within plug ins, i have removed all folders from HAL onto the desktop and tried that and still no updates available. It continues to allow the download but on reboot just shows missing drivers. This is happening on two separate macs running Yosemeti. Really frustrating, any help would be great. Quote Link to comment Share on other sites More sharing options...
writerjosh Posted April 11, 2016 Share Posted April 11, 2016 Hi guys ! It's late but I met the problem willing to check if my Pocket Pod was up to date ! And Monkey was not, and it said it could install because of the OS X version ... So I read ALL the items of this page ... nothing worked ! So I downloaded the Monkey in the Line 6 support/download page : TADAAA ! No more problem . So ! Enjoy ... This fixed everything for me too. Since I don't have a /HAL/ folder, nor Avid drivers etc, this worked: 1) go here: http://de.line6.com/software/?submit=Show&name=Line+6+Monkeyand download. 2) our idiot Monkey friend should reinstall itself. 3) and THEN you can run the updates for your outdated drivers. Bingo. All fixed for me. If only there were some kind of "helper Monkey thing" that could do all this. If only I could call him up and he could find any updates I needed and fix these issue automatically. If only he didn't get sick and die every time there's an OSX update. Of course I have to reinstall him every time. How stupid of me. Every time I need to use an app, I need to reinstall it. Got it. Stupid, stupid, me. (I swear to god when become a rich man I'm ditching all my Line6 gear. Until then, I suffer... ) Quote Link to comment Share on other sites More sharing options...
ofek Posted February 4, 2018 Share Posted February 4, 2018 2018 same problome Quote Link to comment Share on other sites More sharing options...
