pepechin Posted September 20, 2014 Share Posted September 20, 2014 Hi I use iPhone 4S with Roland V-Drums app. Just upgraded to iOS 8 and Midi stopped to work. The app doesn't receive nothing and also there's no led activity in the interface. I don't know if the problem is in the app or in the MIDI interface. Some advice? Thanks Quote Link to comment Share on other sites More sharing options...
gavpod Posted September 30, 2014 Share Posted September 30, 2014 Hi, I experienced the same issue this past weekend when try to use the mobilizer with an behringer fcb1010 to trigger loops on my ipad 2. It worked great before iOS 8, what now? G. Quote Link to comment Share on other sites More sharing options...
boykollee Posted January 4, 2015 Share Posted January 4, 2015 Hi I've the same problem. After update to IOS 8 the MIDI Mobilizer II does not work anymore. I have an iPad Air 2 with several MIDI apps. Alchemie does see the Mobilizer II but gets no signals. Thanks in advanced. Quote Link to comment Share on other sites More sharing options...
olivodc Posted January 5, 2015 Share Posted January 5, 2015 I have the same problem. I tried this on an iPhone 4s and iPad 3 with iOS 8 and you can see the mobilizer but you cannot send messages. I bought these for the school I teach at. Luckily the iPads at the school are still running iOS 7 for now. They work perfectly. Is there any information available about an update at this point? Quote Link to comment Share on other sites More sharing options...
ACqua42 Posted February 2, 2015 Share Posted February 2, 2015 Same here. Just bought it, could even update the software with my iphone 4S with iOS 8 - but MIDI doesn't work But works on my iPod with iOS5 without problems on my Kurzweil Artis... ACqua Quote Link to comment Share on other sites More sharing options...
Jief666 Posted May 5, 2015 Share Posted May 5, 2015 I just got a Midi Mobilizer II. I have an Iphone 4s ios 8.2. It works sometime, but I don't know when or how I've made it works. When it doesn't, it is seen by apps but no midi events, like all of you. Line6, shouldn't you do something ? Jief Quote Link to comment Share on other sites More sharing options...
olivodc Posted May 6, 2015 Share Posted May 6, 2015 I opened a support ticket for my MIDI Mobilizer II about this iOS 8 issue. The response from Line 6 was that they would send a replacement MIDI Mobilizer. I am still waiting on this, so I can't confirm if it was an issue with the hardware or iOS8. It should be noted that the representative at Line 6 said that he had never heard of this issue, so I gave him to the link to this forum. I am confused as to the point of posting to these forums if no one from Line 6 checking them for major issues like this. The MIDI Mobilizer is not working with any apps on iOS8 including the Line 6 provided MIDI Memo at this point and as far as I can tell it only did once for a few minutes. The school I work at went with the Yamaha i-MX1 and they are working fine across operating systems. Quote Link to comment Share on other sites More sharing options...
olivodc Posted May 12, 2015 Share Posted May 12, 2015 Hello Everyone, After opening a support ticket, I received a new MIDI Mobilizer from Line 6 today. It doesn't work on any device running iOS8. As I mentioned in my previous post this is not an issue with these devices using an iDevice to MIDI interface as they can use the i-MX1 with no issue. This thing is useless and I can't return it to the vendor at this point. Lame. Quote Link to comment Share on other sites More sharing options...
olivodc Posted May 29, 2015 Share Posted May 29, 2015 Just got this from the open support ticket: Hi. Our test lab confirms this is a bug with some potential workarounds. I do not yet know when it will be fixed. It does appear that using Midi Memo Recorder to PLAY midi OUT or launching an app that sends MIDI OUT seems to trick functionality back into working. It seems that sometimes an iOS device restart is also needed. Unplugging/Replugging the Midi Mobilizer II also sometimes works. Try this. Quote Link to comment Share on other sites More sharing options...
Jonkos70 Posted May 3, 2019 Share Posted May 3, 2019 I was just sold a new Line 6 Midi Mobilizer from the music store only to find out that the apps are longer available from Apple App store. What a scam! Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 3, 2019 Share Posted May 3, 2019 It should still be available. I just looked ii up, and I still see it. The app is called MIDI Memo Recorder. Quote Link to comment Share on other sites More sharing options...
Jonkos70 Posted May 3, 2019 Share Posted May 3, 2019 Sorry, I see this is the Midi Mobilizer II forum. I am talking about the Midi Mobilizer I with the old iphone/ipad dock, not the lightning cable. This version of MIDI Memo Recorder will not download on my device. All the older Line6 apps are not available unless someone has already purchased them before they were updated. I was so happy to see the Midi Mobilizer I still available at the music store, hoping to use my old ipad again and discovered that Apple no longer has the software. Only Line 6 could provide the older version directly and maybe install manually the .ipa I guess, no idea how that would work. Compatible with all iPhone and iPod touch models. (iPhone, iPhone 3G, iPhone 3GS, iPod touch, iPod Touch 2G) Quote Link to comment Share on other sites More sharing options...
Jonkos70 Posted May 3, 2019 Share Posted May 3, 2019 SOLVED!!!! Login to App store with a new iphone, download MIDI Memo Recorder. Then go to older ipad, in App store browse recently purchased items. Download MIDI Memo Recorder again, this time it will allow downloading the older version. Thanks Phil for the tip "MIDI Memo Recorder." Too bad most of the other software is also not available but at least something works. YEAH!!! Quote Link to comment Share on other sites More sharing options...
BORINS Posted October 7, 2019 Share Posted October 7, 2019 This is low cost and okay. pak talk show It does what it says it will do. I am satisfied, it does the job Cheap. Quote Link to comment Share on other sites More sharing options...
