macOS 13 Ventura/Intel Compatibility
日本語は下記をご覧ください
Voir ci-dessous pour le Français
Siehe unten für Deutsch
Vea abajo para Español
Vedi sotto per l'italiano
Line 6 Software compatible with macOS 13 Ventura/Intel
The following applications have been tested for general compatibility with macOS 13 Ventura running on Intel CPU systems, with no issues found.
Metallurgy Collection
Helix Native
Line 6 License Manager
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
POD HD300 Edit
POD HD400 Edit
PowerCab Edit
Spider V Remote
Workbench HD
Helix Hardware Driver
POD Go Hardware Driver
Universal Intel/M1 Driver 1.0.0 (TonePort/POD Studio/POD HD)
Line 6 Software with limited compatibility with macOS 13 Ventura/Intel
POD Farm 2.5 (Standalone/Plugin): Pod Farm 2.5 works as a standalone app. It also works as a 64-bit plugin in Ableton (AU), Garageband (AU), Logic (AU), Reaper (AU), and Studio One (AU). Pod Farm 2.5 does not work as a 32-bit VST in Ableton, Cubase, Reaper, and Studio One.
Echo Farm 3.0: Echo Farm works in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST), and Reaper (AU/VST). Echo Farm does not work in Garageband (AU). Believed to be iLok-related. We suggest ensuring that the latest version of your DAW and iLok License Manager are installed, and the licenses re-authorized.
Known issues on the Mac forum: Fatal Error: 100001
https://discussions.apple.com/thread/253693434
Amp Farm 4.0: Amp Farm works in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST), and Reaper (AU/VST). Amp Farm does not work in Garageband (AU). Believed to be iLok related. We suggest ensuring that the latest version of your DAW and iLok License Manager are installed, and the licenses re-authorized.
Line 6 Hardware compatible with macOS 13 Ventura/Intel
The following hardware products have been tested for general compatibility with macOS 13 Ventura running on Intel CPU systems, with no issues found when using the latest available Line 6 driver or the macOS 13 class-compliant driver, as applicable.
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • PowerCab family of products
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • Spider V family of products
  • FBV3
  • Firehawk 1500/FX
  • Relay family of products
  • AMPLIFi family of products
  • Mobile Keys 25/49
  • Sonic Port VX
  • POD Studio/Toneport
  • StageScape M20d
  • POD X3 family of products
  • PODxt family of products
  • GuitarPort
  • Variax USB Interface
  • Variax
Additionally, the Apple Silicon M1 chip compatibility KB article lives here.
We encourage anyone experiencing issues with our software to contact our support staff at www.Line6.com/company/contact.
Line 6ソフトウェア製品のmacOS 13 Venturaとの互換性情報
以下のアプリケーションのmacOS 13 Venturaとの互換性を検証し、問題なく動作することを確認しています。このリストは、他のアプリケーションがテストされ、互換性があると見なされたときに、進捗状況に応じて更新されます。
Helix Native
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
PowerCab Edit
Spider V Remote
Workbench HD
macOS 13 Ventura/Intelとの互換性が制限されたLine 6ソフトウェア
POD Farm 2.5(スタンドアロン/プラグイン):Pod Farmは、AbletonAU)、LogicAU)、ReaperAU)、Studio OneAU)でスタンドアロンおよびプラグインとして動作機能します。 AbletonCubaseReaperStudioOneではVSTとしては動作機能しません。
Echo Farm 3.0Echo Farmは、Pro ToolsAAX)、AbletonAU / VST)、CubaseVST)、LogicAU)、Studio OneAU / VST)、およびReaperAU / VST)で動作します。GaragebandAU)では動作機能しません。
Amp Farm 4.0Amp Farm は、Pro ToolsAAX)、AbletonAU / VST)、CubaseVST)、LogicAU)、Studio OneAU / VST)、、Reaperで動作します。  Amp Farmは、Garageband AU では動作しません。
Line 6のハードウェアとmacOS13Venturaとの互換性
以下のハードウェア製品は、IntelCPUシステムで実行されているmacOS13 Venturaとの一般的な互換性についてテストされており、最新のLine 6ドライバーまたはmacOS13クラスコンプライアント・ドライバーを使用して問題 なく動作することを確認しています このリストは、他のアプリケーションがテストされ、互換性があると見なされたときに、進捗状況に応じて更新されます。
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • FBV3
  • Firehawk 1500/FX
  • Mobile Keys
  • Sonic Port VX
  • StageScape M20d
  • Guitarport
  • Variax
Line 6ソフトウェア製品との互換性で問題が生じている場合は、www.Line6.com/company/contactへアクセスし、サポートスタッフまでお問い合わせください。
Line 6サポートチーム
Compatibilité des logiciels Line 6 avec macOS 13 Ventura
La compatibilité générale des applications suivantes a été testée avec macOS 13 Ventura et aucun problème n’a été détecté. Cette liste sera mise à jour avec nos progrès sur d'autres applications au fur et à mesure qu'elles sont testées et jugées compatibles.
Helix Native
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
PowerCab Edit
Spider V Remote
Workbench HD
Logiciel Line 6 avec compatibilité limitée avec macOS 13 Ventura/Intel
POD Farm 2.5 (Autonome/Plugin): Pod Farm fonctionne de manière autonome et en tant que plug-in dans Ableton (AU), Logic (AU), Reaper (AU) et Studio One (AU). Pod Farm ne fonctionne pas comme un VST dans Ableton, Cubase, Reaper et Studio One.
Echo Farm 3.0: Echo Farm fonctionne dans Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) et Reaper (AU/VST). Echo Farm ne fonctionne pas dans Garageband (AU).
Amp Farm 4.0: Amp Farm fonctionne dans Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) et Reaper (AU/VST). Amp Farm ne fonctionne pas dans Garageband (AU).
Compatibilité matérielle de Line 6 avec macOS 13 Ventura
La compatibilité générale des produits matériels suivants a été testée avec macOS 13 Ventura exécuté sur des systèmes à processeur Intel, aucun problème n'ayant été détecté lors de l'utilisation du dernier pilote Line 6 disponible ou du pilote conforme à la classe macOS 13, selon le cas. Cette liste sera mise à jour avec nos progrès sur d'autres applications au fur et à mesure qu'elles sont testées et jugées compatibles.
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • FBV3
  • Firehawk 1500/FX
  • Mobile Keys
  • Sonic Port VX
  • StageScape M20d
  • Guitarport
  • Variax
Nous invitons toute personne qui rencontrerait des problèmes avec nos logiciel à contacter notre service d’assistance à l’adresse www.Line6.com/company/contact.
L’équipe d’assistance Line 6
Line 6 Software-Kompatibilität mit macOS 13 Ventura
Die folgenden Anwendungen wurden auf allgemeine Kompatibilität mit macOS 13 Ventura auf Intel-CPU-Systemen getestet, wobei keine Probleme festgestellt wurden. Diese Liste wird fortlaufend aktualisiert, sobald weitere Anwendungen getestet und für kompatibel befunden werden.
Helix Native
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
PowerCab Edit
Spider V Remote
Workbench HD
Line 6 Software mit eingeschränkter Kompatibilität mit macOS 13 Ventura/Intel
POD Farm 2.5 (Standalone/Plugin): Pod Farm funktioniert als Standalone und als Plugin in Ableton (AU), Logic (AU), Reaper (AU) und Studio One (AU). Pod Farm funktioniert nicht als VST in Ableton, Cubase, Reaper und Studio One.
Echo Farm 3.0: Echo Farm funktioniert in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) und Reaper (AU/VST). Echo Farm funktioniert nicht in Garageband (AU).
Amp Farm 4.0: Amp Farm funktioniert in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) und Reaper (AU/VST). Amp Farm funktioniert nicht in Garageband (AU).
Line 6 Hardware-Kompatibilität mit macOS 13 Ventura
Die folgenden Hardwareprodukte wurden auf allgemeine Kompatibilität mit macOS 13 Ventura auf Intel-CPU-Systemen getestet. Dabei wurden keine Probleme festgestellt, wenn der neueste verfügbare Line 6 Treiber oder der macOS 13 Class-Compliant Treiber verwendet wird. Diese Liste wird fortlaufend aktualisiert, sobald weitere Anwendungen getestet und für kompatibel befunden werden.
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • FBV3
  • Firehawk 1500/FX
  • Mobile Keys
  • Sonic Port VX
  • StageScape M20d
  • Guitarport
  • Variax
Dennoch möchten wir alle Anwender, die Probleme mit unserer Software haben, bitten, sich unter www.Line6.com/company/contact an unsere Support-Abteilung zu wenden.
Ihr Line 6 Support-Team
Compatibilidad del software de Line 6 con macOS 13 Ventura
Se ha probado la compatibilidad general de las aplicaciones siguientes con macOS 13 Ventura y no se han encontrado problemas. Esta lista se actualizará con nuestro progreso en otras aplicaciones a medida que se prueben y se consideren compatibles.
Helix Native
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
PowerCab Edit
Spider V Remote
Workbench HD
Software Line 6 con compatibilidad limitada con macOS 13 Ventura/Intel
POD Farm 2.5 (independiente/complemento): Pod Farm funciona de forma independiente y como complemento en Ableton (AU), Logic (AU), Reaper (AU) y Studio One (AU). Pod Farm no funciona como VST en Ableton, Cubase, Reaper y Studio One.
Echo Farm 3.0: Echo Farm funciona en Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) y Reaper (AU/VST). Echo Farm no funciona en Garageband (AU).
Amp Farm 4.0: Amp Farm funciona en Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) y Reaper (AU/VST). Amp Farm no funciona en Garageband (AU).
Compatibilidad de hardware de Line 6 con macOS 13 Ventura
Se probó la compatibilidad general de los siguientes productos de hardware con macOS 13 Ventura que se ejecutan en sistemas de CPU Intel, y no se encontraron problemas al usar el controlador Line 6 más reciente disponible o el controlador compatible con la clase macOS 13, según corresponda. Esta lista se actualizará con nuestro progreso en otras aplicaciones a medida que se prueben y se consideren compatibles.
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • FBV3
  • Firehawk 1500/FX
  • Mobile Keys
  • Sonic Port VX
  • StageScape M20d
  • Guitarport
  • Variax
Si se presenta algún problema con nuestro software, lo invitamos a que se ponga en contacto con nuestro equipo de atención al cliente en www.Line6.com/company/contact.
El equipo de atención al cliente de Line 6
Compatibilità del Software Line 6 con macOS 13 Ventura
È stata testata la compatibilità delle seguenti applicazioni con macOS 13 Ventura, non è stato riscontrato nessun problema. Questo elenco verrà aggiornato con i nostri progressi su altre applicazioni in quanto testate e ritenute compatibili.
Helix Native
Line 6 Updater
HX Edit
Catalyst Edit
POD Go Edit
POD HD Edit
POD HD Pro X Edit
POD HD500 Edit
POD HD500X Edit
PowerCab Edit
Spider V Remote
Workbench HD
Software Line 6 con compatibilità limitata con macOS 13 Ventura/Intel
POD Farm 2.5 (Standalone/Plugin): Pod Farm funziona come standalone e come plug-in in Ableton (AU), Logic (AU), Reaper (AU) e Studio One (AU). Pod Farm non funziona come VST in Ableton, Cubase, Reaper e Studio One.
Echo Farm 3.0: Echo Farm funziona in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) e Reaper (AU/VST). Echo Farm non funziona in Garageband (AU).
Amp Farm 4.0: Amp Farm funziona in Pro Tools (AAX), Ableton (AU/VST), Cubase (VST), Logic (AU), Studio One (AU/VST) e Reaper (AU/VST). Amp Farm non funziona in Garageband (AU).
Compatibilità hardware della linea 6 con macOS 13 Ventura
I seguenti prodotti hardware sono stati testati per la compatibilità generale con macOS 13 Ventura in esecuzione su sistemi CPU Intel, senza che siano stati riscontrati problemi quando si utilizza il driver Line 6 più recente disponibile o il driver conforme alla classe macOS 13, a seconda dei casi. Questo elenco verrà aggiornato con i nostri progressi su altre applicazioni in quanto testate e ritenute compatibili.
  • Catalyst
  • Helix
  • Helix LT
  • Helix Rack
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • POD Go
  • POD Go Wireless
  • POD HD
  • POD HD Pro
  • POD HD Pro X
  • POD HD500
  • POD HD500X
  • POD HD300
  • POD HD400
  • FBV3
  • Firehawk 1500/FX
  • Mobile Keys
  • Sonic Port VX
  • StageScape M20d
  • Guitarport
  • Variax
Invitiamo chiunque rilevi problemi con il nostro software a contattare il nostro staff di supporto su www.Line6.com/company/contact
Lo Staff di Supporto Line 6
