Right , so I got the Line 6 Po Studio GX and  tried to install the thing . It was all good until I reached the point when it asked if I allow the program to use the speakers/microphone . When I pressed 'allow' The installation froze . I also tried 'don't allow' to see if it makes a differance , but nope the same thing happened again....
A reply would be very much appriciated.
ahhh... then you probably have UAC enabled....
go to the start menu type UAC
hit enter...
put slider at the lowest setting...
reboot...
try again.
this will disable the UAC (user access control) which is prompting you...
you can return to the UAC screen and turn it back on after the fact... (i wouldn't bother...)
