roesler13 Posted November 5, 2014 Share Posted November 5, 2014 hello everybody, I'm having a bit of a problem achieving high volume with my hd 500 hooked up to my peavey 5150 using the four cable method. At the moment when my pod is hooked up I can talk over my amp at max volume. There is no problem with how it sounds, just the volume. When increasing the lead post volume with the pod hooked up, I hear my amp get more distorted and noisy, but the guitar volume stays the same. Settings: The master volume on my pod is 100% with the 1/4" out settings set to amp, and guitar in set to normal. Guitar -> pod guitar in pod fx send -> amp guitar in Pod R/mono -> amp return Pod fx return -> amp fx send Quote Link to comment Share on other sites More sharing options...
stumblinman Posted November 6, 2014 Share Posted November 6, 2014 Did you try center balancing your mixer? hello everybody, I'm having a bit of a problem achieving high volume with my hd 500 hooked up to my peavey 5150 using the four cable method. At the moment when my pod is hooked up I can talk over my amp at max volume. There is no problem with how it sounds, just the volume. When increasing the lead post volume with the pod hooked up, I hear my amp get more distorted and noisy, but the guitar volume stays the same. Settings: The master volume on my pod is 100% with the 1/4" out settings set to amp, and guitar in set to normal. Guitar -> pod guitar in pod fx send -> amp guitar in Pod R/mono -> amp return Pod fx return -> amp fx send Quote Link to comment Share on other sites More sharing options...
radatats Posted November 6, 2014 Share Posted November 6, 2014 hello everybody, I'm having a bit of a problem achieving high volume with my hd 500 hooked up to my peavey 5150 using the four cable method. At the moment when my pod is hooked up I can talk over my amp at max volume. There is no problem with how it sounds, just the volume. When increasing the lead post volume with the pod hooked up, I hear my amp get more distorted and noisy, but the guitar volume stays the same. Settings: The master volume on my pod is 100% with the 1/4" out settings set to amp, and guitar in set to normal. Guitar -> pod guitar in pod fx send -> amp guitar in Pod R/mono -> amp return Pod fx return -> amp fx send Probably a typo but it should be: Guitar -> pod guitar in pod fx send -> amp guitar in amp FX send -> pod fx return Pod R/mono -> amp fx return give it a whirl... also, be sure that the POD FX switch is set to Line as is the switch beside the expression pedal. Check to see that the FX send and return levels are turned up, check if there is a send/return level adjustment on the 5150 too. Silly question but, is the 5150 full volume with just the guitar in (no POD or pedals)? Quote Link to comment Share on other sites More sharing options...
roesler13 Posted November 7, 2014 Author Share Posted November 7, 2014 Hey thanks for the reply. Yea that's the way my cables are hooked up. I tried changing it to line in but didn't seem to change much. Yes, without the pod if the post goes above 1 or 2 it's impossible to talk over. The mixer settings are panned center. Quote Link to comment Share on other sites More sharing options...
radatats Posted November 7, 2014 Share Posted November 7, 2014 Sorry but you didn't say if you checked the POD FX loop send and return levels. I know this sounds dumb but is the POD FX loop block turned on? It sounds like maybe the guitar signal is going straight to the amp FX return without going through the 5150 preamp... It has happened to me before where I put the block in the chain but forgot to turn it on... Quote Link to comment Share on other sites More sharing options...
roesler13 Posted November 8, 2014 Author Share Posted November 8, 2014 Thanks again for the reply. Yes the fx loop is turned on and I've tried it all over the chain. The send and return levels are default Quote Link to comment Share on other sites More sharing options...
roesler13 Posted November 9, 2014 Author Share Posted November 9, 2014 It's working with out a cable plugged into the amps return. Removing the fx send - amp return fixed it and allowed me to use my amps post volume. Thanks for all the replies! Quote Link to comment Share on other sites More sharing options...
DarthHollis Posted November 10, 2014 Share Posted November 10, 2014 Try these patches I use: http://line6.com/customtone/tone/496052/ http://line6.com/customtone/tone/496053/ http://line6.com/customtone/tone/496054/ http://line6.com/customtone/tone/496055/ Reach out to me if you have any questions. One thing to rmember is that the Post Volume on the amp is before the FX send.... not after the FX return on the amp. You may be doing something in the POD that is keeping the volume low and now know it. Are you using amp sims in the POD? If it helps, here is a video I did with the presets above. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
