philthejuggler Posted November 29, 2014 Share Posted November 29, 2014 Has anyone got charging to work through the Sonic Port? My iPad simply says 'not charging' when I connect the power cable. Quote Link to comment Share on other sites More sharing options...
joecozzi Posted December 2, 2014 Share Posted December 2, 2014 Hello,Are you using the supplied Line 6 micro-USB cable into your Apple adapter? Quote Link to comment Share on other sites More sharing options...
philthejuggler Posted December 3, 2014 Author Share Posted December 3, 2014 Yes! Quote Link to comment Share on other sites More sharing options...
joecozzi Posted December 3, 2014 Share Posted December 3, 2014 If you are using the supplied 14pin to lightning cable and the micro USB to your Apple adapter, it should work properly. This could be a broken cable or other hardware. Please contact us so we can replace the device. The US support team can be reached at 818-575-3600 (option 2), Mon-Fri 8am - 5 pm PST. Our busiest hours are from 11am to 2 pm.The UK support team can be reached at +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT. Quote Link to comment Share on other sites More sharing options...
fatherflot Posted December 22, 2014 Share Posted December 22, 2014 Same problem. iPad not charging even when using supplied cords. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 22, 2014 Share Posted December 22, 2014 sometimes it has to do with the computer if that's how you're trying to charge it... i find this helps with those issues (does not require anything "asus") http://event.asus.com/mb/2010/ai_charger/ also when it says "not charging" it definitely sees the power source and it's just not the power level that it likes to see.... often times it is still charging... just very very slowly.. generally enough to keep the battery from going dead. 1 Quote Link to comment Share on other sites More sharing options...
stevekc Posted January 4, 2015 Share Posted January 4, 2015 My SonicPort VX charges my IPhone 6Plus using my 12watt Charger that came with my iPad Quote Link to comment Share on other sites More sharing options...
sunshinewelly Posted January 6, 2015 Share Posted January 6, 2015 How do you charge your ipad if its plugged into the sonic port? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 6, 2015 Share Posted January 6, 2015 there's a cable into the sonicport VX and a cable out of the sonicport VX, i dont think this was an option on the original sonicport. How do you charge your ipad if its plugged into the sonic port? Quote Link to comment Share on other sites More sharing options...
sunshinewelly Posted January 6, 2015 Share Posted January 6, 2015 there's a cable into the sonicport VX and a cable out of the sonicport VX, i dont think this was an option on the original sonicport. cheers that makes sense Quote Link to comment Share on other sites More sharing options...
philthejuggler Posted January 6, 2015 Author Share Posted January 6, 2015 Hi all - I called support who kindly offered to send me replacement cables but they have not yet appeared. Quote Link to comment Share on other sites More sharing options...
sinistralx Posted January 7, 2015 Share Posted January 7, 2015 Have you tried a higher Watt charger? Quote Link to comment Share on other sites More sharing options...
trumblec Posted July 19, 2016 Share Posted July 19, 2016 Brand new cable. Does not charge. Have it connected to a 12w power supply. Has been connected for hours. It is in airplane mode and asleep with no apps running. Quote Link to comment Share on other sites More sharing options...
gk001 Posted September 16, 2016 Share Posted September 16, 2016 Mine is charging fine with various iOS devices Quote Link to comment Share on other sites More sharing options...
Looselectron Posted July 29, 2018 Share Posted July 29, 2018 I'm having the same problem with my new iPad 9.7 even after trying several different cables and chargers. Should I contact Apple about this problem? Quote Link to comment Share on other sites More sharing options...
DanRock101 Posted October 18, 2019 Share Posted October 18, 2019 SAME HERE! I have THREE Sonic Ports,..... two of the 2nd version and one of the 1st version. I've use them on an iPhone 5, iPhone 8, iPad Pro 12.9, and iPad 5.... They used to charge, slowly but they did. Now they don't even register that they're plugged into power. The Sonic Ports work fine BUT they're SUCKING UP the iOS devices' power. Kind of a bummer! Quote Link to comment Share on other sites More sharing options...
