shadowlight Posted June 25, 2013 Share Posted June 25, 2013 I have just bought a pod pro and want to download some tones but It's not listed on the tones page, does that mean I can't get any tones? or does anyone know which ones work with the pod pro? thank you for any replies...Kevin Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted June 25, 2013 Share Posted June 25, 2013 i think you can get the 2.0 stuff. i do believe it;s the same technology Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 25, 2013 Share Posted June 25, 2013 All tones for the basic Pod device should be compatible with the Pro model within the same Pod family. Quote Link to comment Share on other sites More sharing options...
shadowlight Posted June 27, 2013 Author Share Posted June 27, 2013 thank you.. Quote Link to comment Share on other sites More sharing options...
bigglesdog Posted June 28, 2013 Share Posted June 28, 2013 Its just an HD500 in rack-mount form isn't it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 28, 2013 Share Posted June 28, 2013 The Pod HD Pro has additional I/O capabilities compared to the HD500. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted June 28, 2013 Share Posted June 28, 2013 Its just an HD500 in rack-mount form isn't it? this is not about a pod HD pro which is what you are alluding to.... its about an older pod pro (no hd) Quote Link to comment Share on other sites More sharing options...
chrisassassin Posted February 23, 2017 Share Posted February 23, 2017 I just bought a used Pod Pro, and I have downloaded some great tones by title. I have downloaded monkey but it seems that the pull down menu has every line 6 product but the Pod Pro. I have registered it with line 6 and I cant seem to get what I need in Monkey to update the unit much less get these custom tones on it. I may burn it and go back to my boss floor board for my recording needs. Am I doing something wrong here possibly??? Also, i don't have cheap midi cables. cheers Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted February 23, 2017 Share Posted February 23, 2017 don't think you need monkey with the pod pro... to work with tones, you likely need either line6 edit or gearbox. I just bought a used Pod Pro, and I have downloaded some great tones by title. I have downloaded monkey but it seems that the pull down menu has every line 6 product but the Pod Pro. I have registered it with line 6 and I cant seem to get what I need in Monkey to update the unit much less get these custom tones on it. I may burn it and go back to my boss floor board for my recording needs. Am I doing something wrong here possibly??? Also, i don't have cheap midi cables. cheers Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 23, 2017 Share Posted February 23, 2017 IIRC the Original Pod Pro was eprom based and there never really was an update needed for it. So like Zap said - L6 Edit or Gearbox connect your non-cheap cables and have at it. The manual will help too its pretty good. Quote Link to comment Share on other sites More sharing options...
victornamba Posted February 1, 2023 Share Posted February 1, 2023 On 2/23/2017 at 8:54 AM, TheRealZap said: don't think you need monkey with the pod pro... to work with tones, you likely need either line6 edit or gearbox. Hi! I bought last year an old POD PRO Rack. Can I save the actual presets patches and add a new ones? I think that L6 Edit or Gearbox don't run on Macs. There's a new software or any other solution? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 1, 2023 Share Posted February 1, 2023 On 2/1/2023 at 7:54 AM, victornamba said: Hi! I bought last year an old POD PRO Rack. Can I save the actual presets patches and add a new ones? I think that L6 Edit or Gearbox don't run on Macs. There's a new software or any other solution? Thanks The program you want is called POD HD Pro Edit. You can download it from the Downloads tab at the top of this page. Choose POD HD Pro in the Hardware column and choose POD HD Pro Edit in the Software column. Then download and install. I can’t recall whether this includes the required driver. If not you will need to download and install the driver too. Leave the Hardware column with the Pro selected and choose Driver for the software column. Quote Link to comment Share on other sites More sharing options...
