olgerd Posted July 1, 2013 Share Posted July 1, 2013 Hi everyone!) There is a problem: Changes from gearbox to pod xt live doesnt reflect (exception changing amp or stomp) gearbox knobs in Stomp, amp etc doesnt change postion in the pod xt live. But there is reflection from pod xt live to gearbox. When I touch real knobs and buttons - it is reflecting in gearbox too (change position, turn on/off etc). Line 6 Edit works fine, but I prefer Gearbox real-time editing. I try another USB cable - same effect( Сan anyone suggest solution for this problem?! Best regards, olgerd) Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 1, 2013 Share Posted July 1, 2013 Are you clicking "Tone Locker" in Gearbox? If you run Monkey do you have green ticks for drivers? ***Warning, if you purchased your PODxt Live 2nd hand with extra Model Packs, updating your PODxt may cause you to lose your Model Packs if previous owner did not properly "Gift" them to you. Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 1, 2013 Author Share Posted July 1, 2013 Are you clicking "Tone Locker" in Gearbox? If you run Monkey do you have green ticks for drivers? ***Warning, if you purchased your PODxt Live 2nd hand with extra Model Packs, updating your PODxt may cause you to lose your Model Packs if previous owner did not properly "Gift" them to you. Thank you for the answer!) 1) I will check it! (when I return to home) 2) Monkey show all green ticks for drivers and other software/flash memory/drivers/line6edit/gearbox) 3) I purchased modelpacks many years ago and recover my old account. All updates are in time) Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 1, 2013 Share Posted July 1, 2013 No worries on the model packs then. If Tone Locker doesn't solve the issue try different USB ports. Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 1, 2013 Author Share Posted July 1, 2013 I tried another usb port - no effect, Tonelocker doesnot change the effect. If it turn on - with library of the effects/ or turn off - with nothing/ Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted July 8, 2013 Share Posted July 8, 2013 you can always try line6 edit, it may suit your requirements better. Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 8, 2013 Author Share Posted July 8, 2013 you can always try line6 edit, it may suit your requirements better. Yes, I can) But I prefer real-time editing in Gearbox) Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted July 8, 2013 Share Posted July 8, 2013 I haven't used either in over a year, and never used them in any "realtime" fashion... so other than trying the two different programs i'm not sure i can help. did it ever work "realtime"? Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 8, 2013 Author Share Posted July 8, 2013 Maybe I said "real-time" is not clear. I mean that I use Gearbox knobs and hear the result as I use knobs on PodXTLive. Yes, It works before update, I use my PodXTLive so much times ago, and when I connect it to the Monkey, it downloads some updates or (I dont know what, because firmware was 3.01) and I cant use Gearbox for changing volume, changing pedals, using knobs - I can rotate knobs - but there is no real reflection from POD. All Knobs on its screen arent moving. Sorry for my English(.I will try to speak more clearly Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted July 8, 2013 Share Posted July 8, 2013 i'd guess you may have updated the drivers, dig around a try an older version, this might revert back to former behavior. Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 8, 2013 Author Share Posted July 8, 2013 I try older Gearbox, older drivers) Try another computer, another usb cable, another usb. Pod as a separate state works fine - but I cant change the effects and others from PC Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 8, 2013 Share Posted July 8, 2013 So when you run Monkey it sees the PODxt Live and has green ticks for drivers? Quote Link to comment Share on other sites More sharing options...
olgerd Posted July 8, 2013 Author Share Posted July 8, 2013 Yes) Green ticks for all) When I try to use old drivers/gearbox I've got a message to update Quote Link to comment Share on other sites More sharing options...
herr_doctor_F Posted November 3, 2013 Share Posted November 3, 2013 add the line EnableMIDITx=1 to your GearBox.ini. In previous versions of the GearBox application it was possible to deactivate the transmission of MIDI CC data to the connected unit, compare for example the "Line 6 MIDI Continuous Controller Reference". The Default is to not transmit the data. For some reason the according checkbox has been removed from the MIDI Setup tab of the current GearBox version 3.72.0. Luckily, the feature can be enabled throught the ini file. 2 Quote Link to comment Share on other sites More sharing options...
olgerd Posted November 7, 2013 Author Share Posted November 7, 2013 add the line EnableMIDITx=1 to your GearBox.ini. In previous versions of the GearBox application it was possible to deactivate the transmission of MIDI CC data to the connected unit, compare for example the "Line 6 MIDI Continuous Controller Reference". The Default is to not transmit the data. For some reason the according checkbox has been removed from the MIDI Setup tab of the current GearBox version 3.72.0. Luckily, the feature can be enabled throught the ini file. Thank you man! It is my SOLUTION!!! Close this Topic!!! Quote Link to comment Share on other sites More sharing options...
plumberdude Posted October 25, 2014 Share Posted October 25, 2014 I tried this fix but it's still not working. I've got the latest drivers, Any other suggestions? Quote Link to comment Share on other sites More sharing options...
olgerd Posted October 27, 2014 Author Share Posted October 27, 2014 I tried this fix but it's still not working. I've got the latest drivers, Any other suggestions? I sold my PODXt Live this summer. But You can go to the System Setings on your PODXt Live, choose Midi, and try knobs there (i dont remember which are, maybe "on-off" or change another parametr) Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 27, 2014 Share Posted October 27, 2014 I tried this fix but it's still not working. I've got the latest drivers, Any other suggestions? Hey Plumber Dude, You are going to have to list what the problem is and what you are trying to connect it to. Any errors? With L6 Monkey? Gearbox? How are you connecting it? PC/Mac? What OS? What have you tried so far? Stuff like that. If you have another thread somewhere I missed - sorry :) -B Quote Link to comment Share on other sites More sharing options...
plumberdude Posted October 28, 2014 Share Posted October 28, 2014 I'm not going to bother with it, it's not a feature I use that much. I can send changes from gear box to podxt live by clicking the compare tone or reclicking the effect model of whatever I adjusted. (If that makes sense? ) Quote Link to comment Share on other sites More sharing options...
Jameslavelle Posted August 19, 2023 Share Posted August 19, 2023 I had this problem too - hadnt plugged in for a decade. I updated the Pod xt live firmware through Line 6 Monkey and its all working fine now. Quote Link to comment Share on other sites More sharing options...
