I saved my sounds using MKII Edit - is there any POD I can use with them?
uniqueAndreas
I have a HD100 and saved my sounds using the software Spider Valve MkII Edit.
I wonder if there is any POD I can use for smaller gigs where I can upload the sounds from the HD100 that brings me the same sounds.
Can anybody tell?
Thanks in advance,
Andreas
  • 3 weeks later...
Since the PODs use different models and effects, you have to manually recreate them. One way to make it easier is to use the advanced manuals of the HD100 and POD to cross reference the exact (or similar) amp models you are using. Once those amps are dialed in, it's a bit easier to add effects. I wish there was a simpler way, but at least the FBV pedal board is compatible across some PODs.
...So I just tried this with 25 tones from my SVmkII to Pod HD. The models and options are so different that it became easier to just use my ears to decide what sounded similar. Even some of the effects use different terminology for the same parameter. It took all day, but I'm glad that's done!
