rd6966 Posted July 7, 2013 Share Posted July 7, 2013 Turned on my X3 live today and there is no sound just a loud hum and the display is lit, but nothing appears just the yellow back light. It worked fine last night no problems. any ideas ? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 7, 2013 Share Posted July 7, 2013 This is often caused by a failed power supply. If you can try a different one with the EXACT SAME specs it may work. Here is the correct PSU: https://www.globalfulfillment.net/gfsnet/line6/10Expand.aspx?ProductCode=98-030-0042-05 Quote Link to comment Share on other sites More sharing options...
rd6966 Posted July 7, 2013 Author Share Posted July 7, 2013 Didn't work, i had a brand new power supply still in the package, plug it in still the orange but blank screen Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 8, 2013 Share Posted July 8, 2013 Check the On/Off switch on the device; it may be loose. Otherwise you can try to reflash the memory after powering up in Safe Mode. Read the last Question in this document first...... http://line6.com/support/docs/DOC-4698 Failing that your X3 needs servicing: http://line6.com/service_centers/ Quote Link to comment Share on other sites More sharing options...
rd6966 Posted July 8, 2013 Author Share Posted July 8, 2013 Thanks for the help. But it looks like its time to take it in for service. I'll use the original XT Live , I'am glad i still have it, until i get the X3 repaired Thanks again for the help. Rick Quote Link to comment Share on other sites More sharing options...
edwin_2505 Posted December 29, 2013 Share Posted December 29, 2013 i have the same problem and i cant use my pod x3 live, can you help me? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2013 Share Posted December 29, 2013 If it's the same problem, then you should follow the instructions in this thread. The last resort is to take it in for servicing. Quote Link to comment Share on other sites More sharing options...
vulgarus73 Posted August 22, 2014 Share Posted August 22, 2014 Ave. I had the same.In the middle from the power side there is a spool of wire. There are so hopelessly made,so one end of the wire unsolder .Just it solder and everything will be okay :) Weak converter ! Regards. 3 Quote Link to comment Share on other sites More sharing options...
billfish0218 Posted August 9, 2015 Share Posted August 9, 2015 I had the same problem. After inspection I observed that the small spool of wire had come loose from the board (part 221 in vulgaris73 post)and one of the wires came un-soldered. I re-soldered the wire and the unit is working OK. If you are not experienced with soldering I recommend you take your unit to an electronics repair shop or send it in for service. Quote Link to comment Share on other sites More sharing options...
5vdc Posted September 28, 2016 Share Posted September 28, 2016 Thank you so much guys !! I repaired mine in less than 20 minutes :-) Cheers Quote Link to comment Share on other sites More sharing options...
ifgc-sda9 Posted January 22, 2017 Share Posted January 22, 2017 i have same issues bout that, please help... i got a blank screen yellow, nosound , no text display....confuse thanks for all rplays Quote Link to comment Share on other sites More sharing options...
mrhell666 Posted September 2, 2021 Share Posted September 2, 2021 man is great, i repair in minutes thanks you are great Quote Link to comment Share on other sites More sharing options...
